Gas + Compression ratio #2530943
08/03/18 01:24 PM
08/03/18 01:24 PM
Keymar, MD
DusterKid Offline OP
Keymar, MD
Building a 408 stroker with eddy 63cc alum heads .551/.570 solid cam, race only motor that will be spun to 6500. What would be the max compression ratio for running a mixture of 3 gal of 93 pump gas with 2 gal 110 sunoco race gas (comes to 99.8 octance I guess?).
Re: Gas + Compression ratio [Re: DusterKid] #2530945
08/03/18 01:29 PM
08/03/18 01:29 PM
New York
polyspheric Offline
polyspheric  Offline
New York
With what mixture?
What spark curve?
What quench distance?
What intake valve closing point?
Boffin Emeritus
Re: Gas + Compression ratio [Re: polyspheric] #2530964
08/03/18 01:50 PM
08/03/18 01:50 PM
Keymar, MD
Keymar, MD
Originally Posted By polyspheric
With what mixture?
What spark curve?
Cam specs:
Advertised Duration (Int/Exh): 290/302
Duration @ .050 (Int/Exh): 256/268
Gross Valve Lift (Int/Exh): .550/.571
LSA/ICL: 106/102
Valve Lash (Int/Exh): .024/.026
Not sure on quench distance yet, as playing around with head gasket thickness
