cam tolerances #2530777
08/03/18 12:37 AM
08/03/18 12:37 AM
ky, usa
littlejohn44 Offline OP
ky, usa
What would yall allow for tolerance wear on your valve train? I had heads cut so now i'm trying to measure for new push rods and have found +/- .001-.002 on the cam lobes.
Re: cam tolerances [Re: littlejohn44] #2530885
08/03/18 11:38 AM
08/03/18 11:38 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I wouldn’t be worried about 1 or 2 thou.
