hood hinges fiberglass hood #2528808
07/29/18 10:39 PM
07/29/18 10:39 PM
Fredericksburg Va
P
plycuda Offline OP
plycuda  Offline OP
P
Fredericksburg Va
I have stock hinges with a hood prop. wondering has anyone made or have an idea on how to make it open farter. a lift off hood makes it nice to work on but the hinged hood makes it easy when your by yourself I just wish it would go up farther to get in there easier.
Re: hood hinges fiberglass hood [Re: plycuda] #2528836
07/29/18 11:47 PM
07/29/18 11:47 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
A or E Barracuda?
On my '72 Duster with 'glass hood, stock hinges with springs removed, I can get the hood almost vertical.
B & E hinges are completely different, though.
Re: hood hinges fiberglass hood [Re: topside] #2528920
07/30/18 08:52 AM
07/30/18 08:52 AM
Fredericksburg Va
P
plycuda Offline OP
plycuda  Offline OP
P
Fredericksburg Va
B body
Re: hood hinges fiberglass hood [Re: plycuda] #2529114
07/30/18 04:09 PM
07/30/18 04:09 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I don't have a B hinge handy to ponder & play with, but I wonder if one couldn't be modified for more travel.
Another thought is the hot rod & custom guys, but that could be $pendy...
Re: hood hinges fiberglass hood [Re: plycuda] #2529182
07/30/18 06:39 PM
07/30/18 06:39 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Vaguely recall that some OEM hinges have a bolt traveling in a slot (more than one?) which stops upward hood motion.
Lengthen the slot with a die grinder?
Boffin Emeritus
Re: hood hinges fiberglass hood [Re: plycuda] #2529194
07/30/18 06:52 PM
07/30/18 06:52 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Attach the rear hood pins to the hinges, adjust them down tight. It makes it easy to remove the hood if you need to do more than check the oil but still gives you hinge capability?
I hate the idea of a lift off hood for my street car. But I current;y don't have a hood on the car due to a tunnel ram change and I love the access!
68 Barracuda Formula S 340
Re: hood hinges fiberglass hood [Re: Bad340fish] #2529249
07/30/18 09:19 PM
07/30/18 09:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have a Rampage with a glass hood.. was a pin
on hood but I made up some hinges for it.. was
pretty easy(both arms are the same length)..it
will open almost straight up(have to watch the
rear points of the hood from hitting.. it will
open up plenty enough so I can pull the engine
and trans together or headers
wave
Re: hood hinges fiberglass hood [Re: polyspheric] #2529296
07/30/18 10:32 PM
07/30/18 10:32 PM
Fredericksburg Va
P
plycuda Offline OP
plycuda  Offline OP
P
Fredericksburg Va
the bottom of the hinges look like a gear that meshes together then the 2 hinges hit each other. I might be able to try and cut the 2 edges that hit to get it to open farther.
Re: hood hinges fiberglass hood [Re: plycuda] #2529306
07/30/18 10:54 PM
07/30/18 10:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The only thing that stops my hood is the scoop
hitting the windshield and thats almost straight
wave
Re: hood hinges fiberglass hood [Re: MR_P_BODY] #2529316
07/30/18 11:16 PM
07/30/18 11:16 PM
Fredericksburg Va
P
plycuda Offline OP
plycuda  Offline OP
P
Fredericksburg Va
if I could do that it would be great. I will have to make a new hood prop
