Re: The mighty 318
[Re: quickd100]
#2528591
07/29/18 12:48 PM
07/29/18 12:48 PM
Posts: 10,021 Frostbitefalls MN (Rocky&Bullw...
gregsdart
The f/a ratio was at 12.00 at the end of the pull so I'm going to try and lean it out to 12.5/12.75. Would extra fuel be better? My Saleen blown Mustang makes great power at 11/1 ,7.5 psi, cast pistons, 55,000 hard miles on it.
Re: The mighty 318
[Re: quickd100]
#2528868
07/30/18 12:56 AM
07/30/18 12:56 AM
Posts: 4,213 New York
polyspheric
New York
How low do you have boost, and what A/R is the turbo?
Boffin Emeritus
Re: The mighty 318
[Re: quickd100]
#2529030
07/30/18 02:15 PM
07/30/18 02:15 PM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
Stock short block, 8.9-1 (deck O-ringed with Clark copper head gaskets), 302' heads with 1.88/1.60 valves, summit house grind cam, .441 lift, 218/228@.050 114C. Performer intake, Eddy 600cfm carb.
Re: The mighty 318
[Re: quickd100]
#2529110
07/30/18 04:00 PM
07/30/18 04:00 PM
fast68plymouth
So. Burlington, Vt.
I wonder if the power were better to begin with, if the percentage of change/gain would still be the same, with the same amount of boost per rpm point.
I mean, it should be pretty easy to get close to another 100hp out of that 318 with some head work, headers, faster cam, etc.
If you made 500hp with xx boost from your 229hp starting point, that’s 2.18 times the original power output.
If you started at 330hp, would that same xx boost still increase the output 2.18 times(719hp)?
