Re: heater core replacement 04 Jeep GC
[Re: 6T6Cuda]
#2527740
07/27/18 08:29 AM
07/27/18 08:29 AM
Posts: 603 Mass
charge70
Mass
The aftermarket cores are not as good as the factory ones.I can understand wanting to replace it as you will have the heater box out.What is the difference in price from the factory core to the aftermarket? At work,I allways push for the factory stuff as it is usually better but sometimes the cost prohibits that.
1970 Dodge Charger R/T S.E.
1969 Dodge Dart GTS 440 M-Code
1970 Dodge Charger 500 383/4-speed w/A.C.
[Re: 6T6Cuda]
#2527753
07/27/18 10:00 AM
07/27/18 10:00 AM
Posts: 603 Mass
charge70
Mass
Sometimes the o.e. stuff had problems and the aftermarket parts will be redesigned to correct that but not allways.I would price the o.e. heater core and decide from there.I've never put a heater core in one of those vehicles but that doesn't mean it won't ever fail.
[Re: 6T6Cuda]
#2527812
07/27/18 11:50 AM
07/27/18 11:50 AM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
Installed lots of after market cores and evaps at the shop.Never had a problem with them.Typically we only used factory when customer asked for it.On those like mini vans Durangos etc we always replcade both unless customer didnt want it.Then there was no warranty on the old stuff not going bad.Kind of like changing a water pump when you change a timing belt.We typicall used NAPA or Advance cores.Rocky
Chrysler Firepower
