Page 3 of 3 1 2 3
Re: 73' to 74' Coronet and Charger front ends??? [Re: fullmetaljacket] #2526358
07/24/18 12:59 PM
07/24/18 12:59 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
Looks like you may be in luck on the rubber isolators:
https://www.ebay.com/itm/NEW-1973-1974-P...6MD&vxp=mtr
Re: 73' to 74' Coronet and Charger front ends??? [Re: Montclaire] #2526435
07/24/18 03:08 PM
07/24/18 03:08 PM
fullmetaljacket Offline OP
Thank you Montclaire. The fab Gods must have heard our battle cry for these things through this board. LOL.
I'll take a closer look at them. They are a little pricey, but I understand the demand and especially the time and effort that such a complicated item takes to fabricate and distribute.
Re: 73' to 74' Coronet and Charger front ends??? [Re: fullmetaljacket] #2526444
07/24/18 03:19 PM
07/24/18 03:19 PM
md
mopars4ever Offline
mopars4ever  Offline
md
That`s actually not a bad deal on them. It looks like it comes with the crossmember iso mounts also. NOS would cost much more I`m sure.
Re: 73' to 74' Coronet and Charger front ends??? [Re: mopars4ever] #2526452
07/24/18 03:39 PM
07/24/18 03:39 PM
We're looking into it. That's Frank Mitchels old company that is selling them I believe.
Re: 73' to 74' Coronet and Charger front ends??? [Re: Montclaire] #2526456
07/24/18 03:44 PM
07/24/18 03:44 PM
Since you guys know these parts and related cars much more than I do, are these bushings in the picture correct or at least close to original as it may come?
Two buyers of the product in the last two months have not commented on their fit and or quality. I ask because even though these theoretically are not high pressure load items, the welds seem a little shy as in tack welds. Perhaps the factory produced just as shy a weld on the originals also. LOL.
In either case, if these are indeed the correct types, I will add a small tag weld seam to the corners to make it that much more stronger.
Re: 73' to 74' Coronet and Charger front ends??? [Re: fullmetaljacket] #2526476
07/24/18 04:28 PM
07/24/18 04:28 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
Re: 73' to 74' Coronet and Charger front ends??? [Re: fullmetaljacket] #2526477
07/24/18 04:32 PM
07/24/18 04:32 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
Re: 73' to 74' Coronet and Charger front ends??? [Re: Montclaire] #2526721
07/25/18 01:45 AM
07/25/18 01:45 AM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
Originally Posted By Montclaire
If the K is mounted solid, you can do away with this.
I haven't done this to my wagon (yet) as I have a few good used ones available still.
For the OP, its best to leave it in place as it does lessen some of the harshness fed back up the column.
John
The dream is dead, long live the dream.......šŸ˜„
Re: 73' to 74' Coronet and Charger front ends??? [Re: fullmetaljacket] #2526745
07/25/18 05:35 AM
07/25/18 05:35 AM
Valencia, EspaƱa
NachoRT74 Offline
NachoRT74  Offline
Valencia, EspaƱa
Way away from my budget... couldn't expect less from fmmopar, as any other Mopar repro around.
That's why I created this:
https://www.facebook.com/groups/149414152185365/
( yeah well, just somekind of rant )
One more to add to the expensive list I can't afford, like:
RCD ( bilstein ) shocks
Tuff stuff 100 amps alt
Bumper fillers ( except front center )
Headlight fillers and grilles ( not satisfied yet with headlight fillers repros yet thought )
Can't recall what else...
Re: 73' to 74' Coronet and Charger front ends??? [Re: fullmetaljacket] #2526806
07/25/18 11:27 AM
07/25/18 11:27 AM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
With eighteen pieces in the kit, it works out to less than $17 per piece. The bumper fillers are being produced on the same cottage industry scale so they are not cheap, either, but the quality seems to be there. I for one am glad they are being offered.
Re: 73' to 74' Coronet and Charger front ends??? [Re: Montclaire] #2527657
07/26/18 11:17 PM
07/26/18 11:17 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
I finally got around to checking my column - 50mm center to center. So the triumph part will not work. Bummer.
Re: 73' to 74' Coronet and Charger front ends??? [Re: Montclaire] #2527894
07/27/18 02:57 PM
07/27/18 02:57 PM
A little off guide, but are the 73'-74' Charger front fenders compatible with 73' Coronets?
Re: 73' to 74' Coronet and Charger front ends??? [Re: fullmetaljacket] #2527926
07/27/18 04:05 PM
07/27/18 04:05 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
No, but you can swap bumpers.
Re: 73' to 74' Coronet and Charger front ends??? [Re: Montclaire] #2527936
07/27/18 04:17 PM
07/27/18 04:17 PM
So that means that the 73' Coronet and or perhaps the 74' Coronet fenders are a one to two year thingie only?
Re: 73' to 74' Coronet and Charger front ends??? [Re: fullmetaljacket] #2527949
07/27/18 04:28 PM
07/27/18 04:28 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
I think Coronet is 1972/1973, with 1974 being different. And I think that Satellite sedan is the same 1972-1974. My guess (and this is only a guess) is that there was an issue with the hoop bumper on the Dodge meeting 1974 crash standards.
Re: 73' to 74' Coronet and Charger front ends??? [Re: fullmetaljacket] #2528193
07/28/18 08:41 AM
07/28/18 08:41 AM
Valencia, EspaƱa
NachoRT74 Offline
NachoRT74  Offline
Valencia, EspaƱa
Coronet and Charger are a diff monsters.
Between Coronets, and thinking they could be similar to Chargers all 71/73 should be somehow interchangeable from exterior ( aside 71 sidemarkers ) but actually every year is 1 year only setup because radiator core support differences due the frame rails changes and isolation systems... it seems ridiculous, but the isolation changed a bit the fenders too due the frame rail changes.
Page 3 of 3 1 2 3
