Page 3 of 5 1 2 3 4 5
Re: These plugs too cold? [Re: hemi-itis] #2525510
07/22/18 07:27 PM
07/22/18 07:27 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
14 range. Only does this hot and only out front squirter. Alot of heat hitting front bowl from flex fan. Wheres that video Dom?
Re: These plugs too cold? [Re: mopar dave] #2525595
07/22/18 10:24 PM
07/22/18 10:24 PM
Fredericksburg Va
P
plycuda Offline
plycuda  Offline
P
Fredericksburg Va
Originally Posted By mopar dave
Its always idling when it does this. next time i will shut it off and see what happens.
this is what I posted about a while ago. I waited for summer blend and its definitely better but still does it. I found some non ethanol gas and it pretty much quit but it was only 89 octane. I actually just cut out the bottom of the scoop to see if I can get the heat out from under the hood better.
Re: These plugs too cold? [Re: mopar dave] #2525614
07/22/18 10:54 PM
07/22/18 10:54 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Put some type of plastic or wood spacer between the carb and the intake to help with the fuel boiling, especially if your 4 hole/tapered spacers are made out of aluminum.
Re: These plugs too cold? [Re: Blusmbl] #2525628
07/22/18 11:27 PM
07/22/18 11:27 PM
Fredericksburg Va
P
plycuda Offline
plycuda  Offline
P
Fredericksburg Va
I have a 1 inch on mine didn't help
Re: These plugs too cold? [Re: Blusmbl] #2525630
07/22/18 11:27 PM
07/22/18 11:27 PM
Mt Morris Michigan
Mt Morris Michigan
I have a wood 4 hole i will try. currently using a wilson aluminum taper spacer. I havent looked yet but is there a carb/heat shield available to block all that heat coming off the fan?
Re: These plugs too cold? [Re: mopar dave] #2525643
07/22/18 11:55 PM
07/22/18 11:55 PM
Mt Morris Michigan
Mt Morris Michigan
anybody had good results from one of these coolshields?
Re: These plugs too cold? [Re: mopar dave] #2525650
07/23/18 12:14 AM
07/23/18 12:14 AM
Washington
madscientist Offline
Washington
I've been looking at them I just haven't pulled the trigger yet.
Re: These plugs too cold? [Re: madscientist] #2525658
07/23/18 12:26 AM
07/23/18 12:26 AM
Mt Morris Michigan
Mt Morris Michigan
Not sure if that shield would help as i think i have more heat coming off the fan than the engine blowing directly on the pri bowl. May have to try one to see if it helps or not. ill try the wood spacer first.
Re: These plugs too cold? [Re: mopar dave] #2525705
07/23/18 02:38 AM
07/23/18 02:38 AM
One of my old used race cars came with a carb heat deflector made out of sheet of aluminum, the former owner, (9 second Phil) was in the U.S. Air Force at the time doing aircraft maintenance so he made it out I think around .073 to .095? sheet aluminum cut it out the square under the carb. to match the intake manifold and bent the front edge up about three inches in front of the front fuel bowl , he also drilled a hole in the driver side of the bent up lip and used it as the throttle return spring hole up
Lots of ways to skin the kitty wrench
Re: These plugs too cold? [Re: mopar dave] #2525762
07/23/18 10:20 AM
07/23/18 10:20 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
This kind of thing will test your imagination as it did mine over 20 yrs ago.There are many ways to help your problem and depends on what you are willing to do.Would you post a pic of the engine and hood?
Re: These plugs too cold? [Re: Clanton] #2525786
07/23/18 11:35 AM
07/23/18 11:35 AM
Mt Morris Michigan
Mt Morris Michigan
here's a couple pics.
Re: These plugs too cold? [Re: mopar dave] #2525790
07/23/18 11:39 AM
07/23/18 11:39 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I think you could make something to integrate with the filter base plate and pull on/off with it and clear lines,links.
Re: These plugs too cold? [Re: mopar dave] #2525802
07/23/18 11:56 AM
07/23/18 11:56 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Just going to throw this out there,If you make a 3 sided shield that will slide over the carb and be held in by the injection bung on the intake and by the base plate and the material could be silver backed foam or just aluminum.
Re: These plugs too cold? [Re: Clanton] #2525827
07/23/18 12:37 PM
07/23/18 12:37 PM
Mt Morris Michigan
Mt Morris Michigan
Ok, thanks for the ideas. I will take a hard look at it today.
Re: These plugs too cold? [Re: mopar dave] #2525970
07/23/18 05:45 PM
07/23/18 05:45 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Not sure I like that flex fan I see in the pick, looks nice but can be dangerous on a 6000 rpmm plus car. they've been know to break apart and lose a blade.
Re: These plugs too cold? [Re: Sport440] #2526050
07/23/18 08:30 PM
07/23/18 08:30 PM
Fredericksburg Va
P
plycuda Offline
plycuda  Offline
P
Fredericksburg Va
on mine I don't think the problem is heat from the intake. I think its just the heat under the hood from headers and radiator. when mine starts acting up I could pop the hood and use a laser temp and the intake was only around 150. the engine was 170. but the carburetor and air cleaner was over 180. from what I read ethanol boils at 174 degrees
Re: These plugs too cold? [Re: plycuda] #2526104
07/23/18 10:09 PM
07/23/18 10:09 PM
Mt Morris Michigan
Mt Morris Michigan
Thanks for confirming my suspicion with the ethenol in the pump gas. All the heat from the radiator is blown right at the carb. Using a drop base air cleaner is no help either. I did install the wood carb spacer todat, but i dont expect much improvement with that alone. Searching for material to make a shield.
Re: These plugs too cold? [Re: mopar dave] #2526182
07/24/18 12:33 AM
07/24/18 12:33 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
What video..........
Re: These plugs too cold? [Re: Thumperdart] #2526204
07/24/18 01:14 AM
07/24/18 01:14 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Originally Posted By Thumperdart
Shouldn't pull fuel at idle at all but up top under power, actually part of the tune up just check out Shiloh's video of his motor on the dyno.......... thumbs
This video. up
Like said, shouldn't pull fuel at idle. There are anti pull fuel squirters.
Re: These plugs too cold? [Re: mopar dave] #2526209
07/24/18 01:29 AM
07/24/18 01:29 AM
fury4speed Offline
fury4speed  Offline
I like NGK XR5 , they work well and also Autolite 85 work well also.
