Page 4 of 4 1 2 3 4
Re: 1971 RR resto... [Re: cdp] #2524741
07/20/18 08:47 PM
07/20/18 08:47 PM
MO
cdp Offline OP
cdp  Offline OP
MO
Switched tires to 70 series. 60s too low.
Re: 1971 RR resto... [Re: cdp] #2524745
07/20/18 09:01 PM
07/20/18 09:01 PM
MO
cdp Offline OP
cdp  Offline OP
MO
The rear.
Minor issue trying to work out with Waldron exhaust on drivers headpipe clearance.
Re: 1971 RR resto... [Re: cdp] #2541657
08/26/18 06:20 PM
08/26/18 06:20 PM
MN
ryangtogtx Offline
ryangtogtx  Offline
MN
Looking good! What size wheels and tires did you use on the front and back? I was thinking about the same exact wheels for my GTX.
Re: 1971 RR resto... [Re: cdp] #2542245
08/27/18 11:42 PM
08/27/18 11:42 PM
MO
cdp Offline OP
cdp  Offline OP
MO
I went with 15x7's all around. 255x70s rear, 225 or 235 x 70's front. I started with 60's, but they seemed too small to me. 15x8.5's were too tight.
Re: 1971 RR resto... [Re: cdp] #2957143
08/25/21 12:39 AM
08/25/21 12:39 AM
Portland , Oregon, United Stat...
smokes Offline
smokes  Offline
Hello, any update on this build ? hopefully you still have it and are done with it?
Looking for a clean w150 or w200 **72-80 body style In the Pacific Northwest**
Re: 1971 RR resto... [Re: smokes] #2957271
08/25/21 01:02 PM
08/25/21 01:02 PM
Stoney Creek, Ontario, Canada
76Beeper Offline
76Beeper  Offline
Hey cdp, i think you are correct about going to a 70 series tire.
Here's my 71 with a 15 x 8 Weld with a 275-60-15 tire.
Will a 70 series tire fit okay on an 8" wide rim?
Re: 1971 RR resto... [Re: 76Beeper] #2963896
09/14/21 06:35 AM
09/14/21 06:35 AM
MO
cdp Offline OP
cdp  Offline OP
MO
Update: Got the RR out of storage this 9/11 weekend after about an 18-month hibernation. The 71 GTX engine rebuild last year got in the way. Working on some clutch problems and am actually going to get it prepped for a repaint. Too many flaws and some color die-back that bothers me. It is up and running. Sounds great with the CompCams XE274 cam. Anyone else have Mopar_ADHD that keeps them working on too many projects at once?
@76Beeper, yes, a 70 series should work fine on an 8" rim. I experimented with an American Racing TTO with the 255-70 on a 15x8.5, and didn't care for how the bulge was when inflated. It was really close to the wheel lip and just didn't look right, so the tire was remounted on a 15x7, and it worked great for me. My final tire is 255/70 rear, 225/70 front. My front clip isn't on yet, so its hard to see how it fills the wheel wells. The RR is equipped with 3.55 gears, but the drive ratio specs out to 3.23 with tall tire. Something to think about.
Currently, I have the same wheel set on a 71 GTX, same tire, but in 60 series and do not like the stance. IMO, the 70 series is the best combo.
Re: 1971 RR resto... [Re: cdp] #2964927
09/17/21 09:43 AM
09/17/21 09:43 AM
NJ
rdrnr6970 Offline
Your #1 source for current events
rdrnr6970  Offline
NJ
Great looking roadrunners guys! drive
OWNER OF EVERYTHING FROM 1956 300 B,IMPERIAL,NEW YORKER HEMIS,AND NEW HEMI TRUCKS.....5TH GENRAMS.COM... 1969/70 ROADRUNNERS ,DARTS/CORONETS, NORTHEAST HEMI OWNERS ASSOCIATION.....WWW.PHANTASMCUDAS.COM....MOPAR FAMILY FOR 50 YEARS AND STILL GOING!MOPAR OWNER COAST TO COAST!!!!
Re: 1971 RR resto... [Re: rdrnr6970] #2977982
10/24/21 08:18 PM
10/24/21 08:18 PM
MO
cdp Offline OP
cdp  Offline OP
MO
Got my clutch squared away. Turned out that the clutch fork bracket was slightly bent back a little, not allowing the fork to fully engage in the throw out bearing. I went ahead and replaced the side cover of the transmission with a fresh one from Brewers Performance, installed an improved adjustment ball assy. from later model MaMopar, and pulled the clutch spring from under the dash to work better with a diaphragm clutch. Now I have full correct adjustments and everything is new.
Decided that there are a few paint issues I'm not happy with. A bubble in the door corner, a few chips, and a few light spots where full coverage didn't happen. Plus I'm adding exhaust tips and a cut-out valance. So, it will receive a full repaint over this winter. The shop said that they would install and align all sheet metal and decals. So, hopefully, come spring she will nearly completed.
Re: 1971 RR resto... [Re: cdp] #2980384
10/31/21 09:25 PM
10/31/21 09:25 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Looks like a nice car to start with. I look forward to seeing some winter progress pics.
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Page 4 of 4 1 2 3 4
