My 37 with a 96 Dodge 360 has a new electrical issue. Has a
#2524437
07/20/18 11:01 AM
07/20/18 11:01 AM
Posts: 29 Plano, TX
hkestes
Plano, TX
My 37 Plymouth with a 96 Dodge 360 has a new electrical issue. Has a new battery and new starter within the past month. Drove the car last Thursday to runs some errands and it started several times and ran fine. Went out to drive it yesterday and when I turned the key the fans and dash light came on (both currently wired to run constantly) and fuel pump kicked on, but got the click-click-click from the starter like the battery was dead. Then about two seconds later nothing no fans, lights or fuel pump and nothing from the starter when key turned to the start position. Wait for a couple minutes and the entire process would repeat. Threw some jumper cables on it and left my wife's car running for several minutes. Same thing turn key on get fans, lights, pump, click-click-click then everything goes dead. Wait a couple minutes and process repeats. I'm an electrical neophyte I know everyone who understands it says to think of it just like a garden hose current in one end of the wire out the other, but I just can't wrap my head around it. No problem tearing into anything mechanical, but electrical has always given me pause cause I don't want to burn it to the ground. Any ideas where I should start to try and run down this problem? [img] https://moparforums.com/g/picture/9977035[/img]
Re: My 37 with a 96 Dodge 360 has a new electrical issue. Has a
[Re: hkestes]
#2524464
07/20/18 11:48 AM
07/20/18 11:48 AM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
Check all the battery connections and grounds. Sounds like something is loose, corroded or otherwise not making good contact.
[Re: John_Kunkel]
#2524596
07/20/18 03:34 PM
07/20/18 03:34 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Gotta agree here. Biggest load on the battery is starting the engine, so if the battery starts to go that is the first place you will see it have issues. Simple test, if you have a meter, hook it up to the battery and see what it's no load voltage is. 12,8 or so is what you want to see. Then with the meter still attached have someone try to start is and see what the load voltage is then. Bet it virtually goes away.
[Re: hkestes]
#2544312
09/01/18 04:19 PM
09/01/18 04:19 PM
Posts: 29 Plano, TX
hkestes
Plano, TX
Well my starting woes have returned. I have replaced both battery cables, added grounds from block to frame / body to frame and a new starter switch. Things were good for a couple weeks then this week it came back. Luckily for me it has only happened in the driveway not when I was out somewhere with one exception. That one time it did happen out somewhere was Wednesday. Checked the battery cables, and the wires to the starter. The wire on the "S" post was loose. Moved it slightly and it started and made it home. Went out to start it the next day and nothing. Pulled the wires off the starter and noticed that the "S" post was loose. Ran the nut back down on the post and it would not tighten it just continued to turn once the nut was turned. That should not happen should it? This is a brand new starter with a lifetime warranty so other than the hassle of pulling it off and taking it back for the replacement not a big deal.
[Re: hkestes]
#2544553
09/02/18 11:34 AM
09/02/18 11:34 AM
Posts: 19,492 north of coder
moparx
pull the end plate off and look at where the stud passes through the case. be careful, as the cover is spring loaded, and covers the contactor set [that most likely is not the correct name, but i have always called them that] that actuates the starter when you supply 12v to the small post. think of it as a relay setup. you should see a bolt head with an eyelet attached to a wire going into the guts of the starter. if so, tightening that bolt [with the outside nut] will tighten that stud, and you should be back in business. just be careful you don't crack the isolator bushing. however, if you find the wire going into the guts has been soldered to that stud, and has broken off from spinning the stud, it's time to put it back together and return to the parts store. it sounds lots harder than it really is. hope this helps.
