1971 - 72 Road runner air grabber hood center #2524120
07/19/18 03:12 PM
07/19/18 03:12 PM
Stoney Creek, Ontario, Canada
76Beeper Offline OP
76Beeper  Offline OP
I'm looking to buy the fiberglass 1971 Road Runner Air Grabber Center Bubble and Door.
Who's is the best quality?
And any issues with installation?
Thanks.
Re: 1971 - 72 Road runner air grabber hood center [Re: 76Beeper] #2524178
07/19/18 05:43 PM
07/19/18 05:43 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I have heard that the repos are crap. You would be better off trying to find an original.
Re: 1971 - 72 Road runner air grabber hood center [Re: 71birdJ68] #2524208
07/19/18 07:18 PM
07/19/18 07:18 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
The best one out there is the Stinger co. one. It will require hours of work to tap all stud mounts and take hours to make the door functional but when done hard to spot from an original. I had the help of a friend that was a bodyman years back to make mine work. The pieces are like $500 on ebay and then all then all the mounting hardware will set you back about $250 so...
Ron
Re: 1971 - 72 Road runner air grabber hood center [Re: RJS] #2524218
07/19/18 07:44 PM
07/19/18 07:44 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Is that the one that PG In. sells?
Re: 1971 - 72 Road runner air grabber hood center [Re: 71birdJ68] #2524274
07/19/18 10:30 PM
07/19/18 10:30 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Don't believe so, the Stinger one comes in white, PG I believe is Black and made overseas.
You can see a glimpse of it in first picture and afterward in second picture. Note: door wasn't fully closed when I snapped the picture.
Ron
Re: 1971 - 72 Road runner air grabber hood center [Re: 76Beeper] #2525497
07/22/18 07:08 PM
07/22/18 07:08 PM
76Beeper Offline OP
76Beeper  Offline OP
Thanks for the info Ron - I"ll be looking into the one from Stinger. up
Re: 1971 - 72 Road runner air grabber hood center [Re: 76Beeper] #2525547
07/22/18 08:51 PM
07/22/18 08:51 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
This ad doesn't say Stinger but this is exactly what I bought going by the pictures and write-up. It says glue down but like I said I tapped all the bosses and bolted it per factory.
https://www.ebay.com/itm/1971-1972-PLYMO...R/323332827704?
Re: 1971 - 72 Road runner air grabber hood center [Re: 76Beeper] #2526635
07/24/18 10:27 PM
07/24/18 10:27 PM
76Beeper Offline OP
76Beeper  Offline OP
Ron - what about the mounting studs?
Where can I purchase those & are there two different lengths that need to be used?
Re: 1971 - 72 Road runner air grabber hood center [Re: 76Beeper] #2526807
07/25/18 11:27 AM
07/25/18 11:27 AM
JERSEY
RJS Offline
RJS  Offline
JERSEY
I got mine back then from either Frank Badalson or R/T Specialties, remember it was a few years back so don't remember exactly. Yes I believe at least 4 studs need to be longer for the "bell nuts".
Ron
Re: 1971 - 72 Road runner air grabber hood center [Re: 76Beeper] #2527578
07/26/18 08:49 PM
07/26/18 08:49 PM
California City, CA
dart440 Offline
dart440  Offline
California City, CA
Listing 273347964412
https://www.ebay.com/itm/MOPAR-BELL-NUT-STUD-SET-71-72-B-BODY-CHARGER-ROAD-RUNNER-AIR-GRABBER-SET-NEW/273347964412?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
Is this what you are looking for??? themoparshopcom is the seller.
Chuck
When you work on Spaceships for a living, how bad can a workday be?
Re: 1971 - 72 Road runner air grabber hood center [Re: 76Beeper] #2527896
07/27/18 03:01 PM
07/27/18 03:01 PM
76Beeper Offline OP
76Beeper  Offline OP
Yes, those are the ones Chuck.
Thanks for the link... up
