v8 Crank identification #2521984
07/15/18 12:37 AM
07/15/18 12:37 AM
SC304 Offline OP
SC304  Offline OP
Has anyone seen or can recommend a chart or quick reference of crank shaft identification for small and big blocks?
Mike
Re: v8 Crank identification [Re: SC304] #2521993
07/15/18 12:47 AM
07/15/18 12:47 AM
P
Porter67 Offline
Porter67  Offline
P
http://www.mopar1.us/casting.html
Or just google the pn.
Re: v8 Crank identification [Re: Porter67] #2522058
07/15/18 10:41 AM
07/15/18 10:41 AM
SC304 Offline OP
SC304  Offline OP
Thanks I was looking for a quick reference guide by snouts or flanges.
Great website tho, love the garage commandments
Re: v8 Crank identification [Re: SC304] #2524043
07/19/18 12:43 PM
07/19/18 12:43 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
They pretty much all look the same , other than Hemi's having 8 bolt flanges .
What you need is a pair of dial calipers and measure main and/or rod bearing journal sizes.
Re: v8 Crank identification [Re: JohnRR] #2524085
07/19/18 02:21 PM
07/19/18 02:21 PM
dogdays Offline
dogdays  Offline
Yes, the main bearing journal is all you need to know:
2.500", 3.31 stroke (LA not 360)
2.625", 3.38 stroke (B)
2.75", 3.75 stroke (RB)
2.825", 3.58 stroke (LA 360)
360 cast only, others both cast and forged OEM.
R.
Re: v8 Crank identification [Re: SC304] #2524886
07/21/18 09:21 AM
07/21/18 09:21 AM
Locomotion Offline
Locomotion  Offline
Also visual cast & forged crank I.D. Some cast cranks originally came with counterweights on the balancer/damper & converter. But not all. 318 is a good example. I believe the 440-6 crank balancer/damper may be an exception in forged cranks and had external balance weights.
