bench vise valve spring compressor psi checker, accurate?
#2523928
07/19/18 03:34 AM
07/19/18 03:34 AM
RapidRobert
how accurate are they & which one should I get? thank you for your time.
Re: bench vise valve spring compressor psi checker, accurate?
[Re: RapidRobert]
#2524060
07/19/18 01:09 PM
07/19/18 01:09 PM
Posts: 2,861 Pattison Texas
CSK
Pattison Texas
The one I have is way off
[Re: CSK]
#2524068
07/19/18 01:32 PM
07/19/18 01:32 PM
dogdays
There are only two realistic factors for accuracy (or not). What you're looking at is a piston in a cylinder exactly 1.00 square inch in area, and a pressure gauge. Both have to be accurate and if they are, the device is accurate.
As it is much easier to produce a cylinder that is 1.000 square inches, the major source of inaccuracy is the pressure gauge. SO, if the pressure gauge is accurate to within 1%, that is what the device's accuracy is, as well. If one wanted to be idiotic, the distance the centerline of the gauge is above or below the centerline of the cylinder counts too, but it is usually much smaller than the gauge's inaccuracy.
IMHO it is much easier to be inaccurate about measuring the distance between the vice jaws than any other part of this process. If one wishes to be super accurate buy a super accurate gauge and have it calibrated by a deadweight tester traceable to the National Institute of Science and Technology, before the series of spring tests.
There are other less accurate ways to assure accuracy.
R.
[Re: topside]
#2524090
07/19/18 02:27 PM
07/19/18 02:27 PM
BradH
Used to sell one that was accurate within 1%. They're made by an old funny car racer friend of mine. Bench-tested every one. He also sells 'em to Summit, Jeg's, maybe Speedway, which they re-brand as theirs. You can PM me if you like for his phone #. The Proform tester I bought was JUNK. The one I bought from topside some years ago is consistent and pretty accurate, based on what my calibration spring and other "known quantity" springs read.
[Re: RapidRobert]
#2524180
07/19/18 05:46 PM
07/19/18 05:46 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
A friend bought one of the Proform bench top units that uses the hyd cylinder with the pressure gage on it. Brought it down to the shop and we checked it against a PAC calibration spring...... it was waaaay off.
It got sent back.
[Re: lewtot184]
#2524352
07/20/18 02:03 AM
07/20/18 02:03 AM
RapidRobert
Damn! I think I might try a bathroom scales in a drill press! (I read about that once).
[Re: lewtot184]
#2524550
07/20/18 02:35 PM
07/20/18 02:35 PM
RapidRobert
you just have to keep in perspective what your buying. Exactly
