Oil pressure sending unit. #2522854
07/16/18 10:54 PM
07/16/18 10:54 PM
Myrtle Beach, SC formerly the ...
340wedge Offline OP
340wedge  Offline OP
Oil pressure sending unit for 1971 rallye dash 340 Duster. Teflon tape on the threads, Yay or Nay? whistling
1971 Sassy Grass Green Duster 340
2006 Charger Daytona GoMango
Re: Oil pressure sending unit. [Re: 340wedge] #2522857
07/16/18 10:58 PM
07/16/18 10:58 PM
Armada MICH.
DUSTER_340 Offline
DUSTER_340  Offline
Armada MICH.
Yes . What brand sending unit are you using? I just tried installing a Standard brand unit on my 340 with a dual point and that unit was too tall for the distributor to rotate.
Re: Oil pressure sending unit. [Re: 340wedge] #2522903
07/17/18 12:08 AM
07/17/18 12:08 AM
340wedge Offline OP
340wedge  Offline OP
I would have too look but I bought it from a restoration supplier, and it seems the same size by looking at it.
Re: Oil pressure sending unit. [Re: 340wedge] #2522911
07/17/18 12:33 AM
07/17/18 12:33 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
NO TEFLON TAPE
it's electrical and needs a good path to ground, which is thru the threads to the block.
Don't be the exception.
Re: Oil pressure sending unit. [Re: 340wedge] #2522935
07/17/18 02:01 AM
07/17/18 02:01 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
No sealer of any kind. It has to have a solid ground to the block to work.
Re: Oil pressure sending unit. [Re: 340wedge] #2522949
07/17/18 03:09 AM
07/17/18 03:09 AM
340wedge Offline OP
340wedge  Offline OP
Thank you all, no sealer it is! up
