When someone oils down the track
#2522553
07/16/18 02:01 PM
07/16/18 02:01 PM
Posts: 34,928 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Yesterday at local race track
Non-Mopar
At about the 1250 mark, his filter gasket decided to leave its home (Wix)
Put 2 1/2 quarts on the track, he went for a wild ride but, kept it pointed mostly straight , fast car ..
I have known him for most of my life, told him .. don't run it again
"why?) --I said, well I bet you nicked a bearing or two or all
Bet it lost oil for moment and at 6000 + rpms, it hurt it said still has Oil pressure ?
so worried about points, goes up
and dumps the crank on the track , and was really upset about all his bad luck ..
2nd ride was wild again but, got it gathered up
That wasn't bad luck , that was being stubborn
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: When someone oils down the track
[Re: bigdad]
#2522561
07/16/18 02:16 PM
07/16/18 02:16 PM
Posts: 4,457 Washington
madscientist
Washington
Non-Mopar
That wasn't bad luck , that was being stubborn That wasn't stubborn. That was stupid. He isn't paying his mortgage with his winnings. If he is he's a fool. It's his hobby. Not his life. And even then, it's not worth the carnage to do what he did for a trophy that has little value That was just stupid. No excuse. Stupid.
[Re: bigdad]
#2522562
07/16/18 02:16 PM
07/16/18 02:16 PM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Or stupid!!!!!!!!!!!!!! LOL.
[Re: madscientist]
#2522563
07/16/18 02:17 PM
07/16/18 02:17 PM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Non-Mopar
That wasn't bad luck , that was being stubborn That wasn't stubborn. That was stupid. He isn't paying his mortgage with his winnings. If he is he's a fool. It's his hobby. Not his life. And even then, it's not worth the carnage to do what he did for a trophy that has little value That was just stupid. No excuse. Stupid. You beat me.
[Re: bigdad]
#2522565
07/16/18 02:20 PM
07/16/18 02:20 PM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
he has I think at last count 8 drag cars
he had two at the track being raced by others yesterday ( non family)
He is just a dedicated racer, has won several track championships
good guy but, a bit too determined to get back to Memphis
I'm glad he didn't put it on the cage , he did some driving
[Re: pittsburghracer]
#2522568
07/16/18 02:21 PM
07/16/18 02:21 PM
madscientist
Washington
Non-Mopar
That wasn't bad luck , that was being stubborn That wasn't stubborn. That was stupid. He isn't paying his mortgage with his winnings. If he is he's a fool. It's his hobby. Not his life. And even then, it's not worth the carnage to do what he did for a trophy that has little value That was just stupid. No excuse. Stupid. You beat me. HA! It so rare I get the drop on anyone I'm giving myself a morning candy bar!!! I get the giggles when I cut an .080 light!!
[Re: bigdad]
#2522589
07/16/18 02:47 PM
07/16/18 02:47 PM
Posts: 11,621 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Not to mention making a mess for the track to clean up, twice, and endangering the guy in the other lane.
[Re: bigdad]
#2522596
07/16/18 03:00 PM
07/16/18 03:00 PM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
1st time , ok ..but that 2nd one was not needed
[Re: bigdad]
#2522604
07/16/18 03:23 PM
07/16/18 03:23 PM
Posts: 4,689 Wichita
GY3
Wichita
A brand new 'Vette went off the end of the track a couple of years ago at Tulsa Raceway Park when we were there. I was the next one down in his lane and saw backup lights!! Fortunately he was stuck in the gravel. Stock 'Vette, no reason to go off as they have a long shutdown area. He has a belly pan and suspension FULL of gravel and what does he do? Promptly pulls back around to the starting line and dumps that all over the track during his burnout!!
[Re: bigdad]
#2522855
07/16/18 10:55 PM
07/16/18 10:55 PM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
Made my last time run at a Divisional in Tuscon, and heard a rattle on the top end. Told my buddies I was done, that I thought it hurt a piston. It was Saturday night, so we had a BBQ and some beers, and I must've fired the car 10 times so everyone could listen, and they all came to the same conclusion. "It's fine! You're being paranoid! Pull up there for first round in the morning, and if it sounds funny down track, then lift, but at least give yourself a chance!"
They convinced me, so the next morning I rolled into the burnout box, grabbed the line lock, took it to 6K in low, then shifted to second and rolled out of the box. Right before the tires bit, the old 440 locked up and tossed all it's guts on the pavement! Couple of pistons and a freshen, it would still be racing! Nothing was saved in the shortblock, destroyed a nice Milodon pan also!
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: bigdad]
#2522874
07/16/18 11:24 PM
07/16/18 11:24 PM
Posts: 11,721 Portage,michigan
B3422W5
Portage,michigan
Few years back on a Saturday night at Monster Mopar i was racing in no box 4th round. Norwalk. Some here probably remember this. Was about three car lengths behind the guy i was chasing down, he broke out ultra bad( still cant figure that out) just as i crossed the finish line on a 10.01 pass, i went immediately toward the wall in the left lane. I did an excellent job( in hindsight) saving the car from hitting the wall. Got it back to the middle, handled a couple major wiggles, and got it slowed down. Lots of smoke in the rearview mirror, and oops, zero oil pressure. Wix oil filter let go. Back in the pits i am white as a sheet sitting on a trailer while an army of friends jack up the car start brake cleaning under it, all over was oil , and Chuck Millen from Best Machine( who built the motor) offers up fresh oil and a filter. Must have been 50 guys around by this time, all helping in one fashion or another. Tires off, cleaning brakes, you name it, oil had gotten on it. At this point i had zero intention of continuing on in eliminations while the track was getting cleaned up from my mess before the next round. Frankly a little shellshocked and nervous. Somebody said, forget who it was now.... “ get back in that car now or you never will” I ultimately got back in it, drove around the pits trying to find something wrong so i could avoid going back to the staging lanes. I went back, zero issues ever again with that motor, that night, or at all until couple years later it was due for a freshen up due to amount of laps on it. So, results can vary.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: J_BODY]
#2522879
07/16/18 11:29 PM
07/16/18 11:29 PM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
30 years or so as I was going thru the traps I glanced and saw my oil pressure drop. It was an old fashioned.030 over stock crank, stock rod, TRW pistons build that ran highs 9’s in the 1/4 mile. I loaded up and took it home that Sunday. I pulled the oil pan on my open car trailer at home to take a peek. As I started with number one main I pulled the cap and the bearing looked great and left the cap off. Number two was fair and when I pulled the thrust cap I thought I saw something move. Well I did as the crank was busted in half. I pulled the engine on Monday and tore into it changing the crank and bearings. With two friends taking care of the rods I lowered a fresh crank in, finished it up, and raced that Friday. Man I wish I could work like that now. This was evening work as I worked 8-4 in the steel mill.
[Re: bigdad]
#2522970
07/17/18 09:46 AM
07/17/18 09:46 AM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
No, he has multiple race cars and makes many laps , not sure why the gasket blew out, was not a fresh oil change so he told me
#2522999
07/17/18 11:01 AM
07/17/18 11:01 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
30 years or so as I was going thru the traps I glanced and saw my oil pressure drop. It was an old fashioned.030 over stock crank, stock rod, TRW pistons build that ran highs 9’s in the 1/4 mile. I loaded up and took it home that Sunday. I pulled the oil pan on my open car trailer at home to take a peek. As I started with number one main I pulled the cap and the bearing looked great and left the cap off. Number two was fair and when I pulled the thrust cap I thought I saw something move. Well I did as the crank was busted in half. I pulled the engine on Monday and tore into it changing the crank and bearings. With two friends taking care of the rods I lowered a fresh crank in, finished it up, and raced that Friday. Man I wish I could work like that now. This was evening work as I worked 8-4 in the steel mill. I had this happen to a 340, i had made a pass and when I got my helmet off at the ET shack I though the car in front of me was knocking. It was then I noticed my oil pressure gauge bouncing. The car sounded like someone was beating on a frying pan with a spoon. I said this to my friends "oh well it was due to be freshened up anyways as long as its not the crank it will be OK". Took it apart that night and the only thing broken.....the crank! If I had another crank we could have made it back out for the midnight drags.
68 Barracuda Formula S 340
