What cools better #2522295
07/15/18 09:39 PM
07/15/18 09:39 PM
Medina, OH
dart440_72 Offline OP
Medina, OH
I have battled cooling issues for long time. Recently, I saw a post about Champion radiators. People were praising them and how good they were. They said, " I can't get the car over 180* in 95* heat. I on the other hand have the exact opposite problem. So I have a poll before I switch to a Griffin radiator to give that a shot.
What do you use on the street? I'm not concerned about the track because that is a run then shutdown for cooling. I am looking for higher horsepower street driven cars. Mechanical fan and pump? Electric fans and electric pump, combo of both?
What cools better? Electric or Mechanical
multiple choice
Votes accepted starting: 07/15/18 09:34 PM
You must vote before you can view the results of this poll.
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
Re: What cools better [Re: dart440_72] #2522311
07/15/18 10:24 PM
07/15/18 10:24 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
I use a AfCO universal radiator , just had brackets tigged on and adjusted lower hose outlet angle
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: What cools better [Re: dart440_72] #2522324
07/15/18 10:47 PM
07/15/18 10:47 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
In my 512 Duster, I have a Champion aluminum radiator, an aftermarket flex fan, and a shroud. Adding the shroud was worth at least 20 degrees, and the thing never gets over 180 even in traffic on a hot day. No other fans.
Re: What cools better [Re: dart440_72] #2522336
07/15/18 10:56 PM
07/15/18 10:56 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Shroud needed
Boffin Emeritus
Re: What cools better [Re: dart440_72] #2522347
07/15/18 11:24 PM
07/15/18 11:24 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
512 ci, cold ac, driven in 105deg temps,runs 180 all day long, sitting in traffic or not, 2 row ECP rad, 18" 7 blade flexalite mechanical fan, 68 Charger so far runs 11.33 @ 121, just had the car weighed again, 4050 with me.
Re: What cools better [Re: dart440_72] #2522389
07/16/18 01:30 AM
07/16/18 01:30 AM
AndyF Online content
AndyF  Online Content
I have a 512 inch big block in my '65 Coronet. Mechanical fan, shroud and a 22 inch aluminum radiator. I have a 180 thermostat in there and it doesn't get much hotter than 180. My EFI system has a data logger so I can review how hot the coolant temp is after a drive. Hottest I've ever seen is 187 degrees. It gets the hottest if it is sitting in the sun at idle after a hard drive. If the car is moving then the temp stays down around 180. I think that having a correct shroud is super important. You also want some pump speed so make sure the pulley ratio is correct. For a street car you should be driving the water pump a little faster than the crankshaft. The lower the engine speed then the more pulley ratio you want. You need water flow thru the engine in order to remove the heat. The more water flow the better as long as the pump doesn't cavitate.
Re: What cools better [Re: dart440_72] #2522402
07/16/18 03:12 AM
07/16/18 03:12 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The '71 Charger with 500" stroker is still running the stock 26" radiator with the Mopar Performance viscous fan package. I also have a pusher fan in front of the radiator, but mostly use it in the pits to cool the radiator with the engine off. Although this works, it is on the edge, and it temps do creep up on long drives when it is 90+ degrees out.
My '69 Coronet 505" stroker had a Champion 26" 4-core radiator. Pretty good for the cost. With Mopar Performance viscous fan package, no problem cooling. With the Contour (Ford) dual cooling fans replacing mechanical fan, it still cooled good until I added A/C and the A/C condenser in front of the radiator. The extra heat load and reduced air flow from the A/C setup made that combination marginal in hot weather. I think mostly airflow related. I have switched to the Griffin Exact Fit radiator and Larger Spal 13" dual fans. I hope it cools better, but I have made other changes and have not driven the car with that setup yet.
I also had a GlenRay HD Radiator with the mechanical setup, and it worked great, but when switching to the electric fan setup I did not want to mess up that radiator so I set it aside and installed the Champion.
On the Champion radiators, I think in my setup the 3-core may have cooled as well or better than the 4-core because the 4-core is pretty thick and I think that partly reduced the air-flow through the radiator.
Re: What cools better [Re: dart440_72] #2522411
07/16/18 06:35 AM
07/16/18 06:35 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
How does the inside of your radiator look when looking through the cap-opening (w/ coolant drained a bit below the toplevel)?
Are the channel-entries clean and open?
A citric acid treatment cured overheating in a 496ci setup with stock 3-row radiator for me.
The car still has a 1:1 crank:waterpump ratio, but it also has its stock 'narrow' steel shroud with a metal flex-fan partly inside.
Engine has 10.5:1 CR, XR274-solid roller, Edelbrock heads.
Before it had rust and scale-particles blocking the radiator channels and everything had a brownish color.
After the first full day-soak in citric acid, the radiator metal already looked like new, aside from a few deposites near the channel-openings.
After that I let it soak a few days more while occassionally tilting the radiator to agitate the acid inside.
Re: What cools better [Re: dart440_72] #2522425
07/16/18 09:19 AM
07/16/18 09:19 AM
Medina, OH
Medina, OH
I'm running thermocure through it right now. However, it didn't look too bad inside. It seems like the common theme above is mechanical. I have a double electric fan with a shroud covering 95% of the radiator.
Re: What cools better [Re: dart440_72] #2522603
07/16/18 03:20 PM
07/16/18 03:20 PM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
Is there a source for a smaller water pump pulley?
I have a 7" single groove water pump pulley and a 5.75" crank pulley.
Re: What cools better [Re: 65Fury440] #2522605
07/16/18 03:33 PM
07/16/18 03:33 PM
Washington
madscientist Offline
Washington
You are turning the pump way too slow. That isn't even 1:1 unless the crank pulley is the smaller one.
Re: What cools better [Re: dart440_72] #2522610
07/16/18 03:42 PM
07/16/18 03:42 PM
One thing to keep in mind when it comes to radiator selection a copper and brass radiator of the exact same size as a all aluminum or aluminum and plastic tank radiator the materials in them will determine which will cool better, brass and copper work better for cooling shruggy scope
Been there done that with a Griffin cooper and brass versus aluminum of the exact same size and construction other than cross flow versus vertical flow whiney
Re: What cools better [Re: madscientist] #2522622
07/16/18 03:50 PM
07/16/18 03:50 PM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
Yes the crank pulley is smaller. My stock crank pulley was just a little over 6.5", didn't think it would matter a whole bunch.
I looked at a few different vendors and don't see any overdriven water pump pulleys.
That crank pulley was the only diameter Source had when I ordered a new one, my stock pulley had just a little tweak in it. I suppose I could look for a new crank pulley and throw this one in the spare parts box.
Re: What cools better [Re: 65Fury440] #2522695
07/16/18 06:18 PM
07/16/18 06:18 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Decades ago we all bought the Morose aluminum underdrive pulleys to free up a few horsepower. Now that we have stroker kits and good heads we can easily make a lot more power and we are now digging through the junk pile where the spiders live to find the biggest crank pulley so that we can trade a few of those easy hp for some hard to find cooling. Funny how that works.
Re: What cools better [Re: dart440_72] #2522704
07/16/18 06:36 PM
07/16/18 06:36 PM
The Netherlands
The Netherlands
Bigblock cars that originally came with airconditioning had a smaller, dual groove waterpump pulley, but the alignment is off compared to the single groove pulleys.
Takes some spacing and realigning of crank pulley and alternator if you want to go that route.
Re: What cools better [Re: BigBlockMopar] #2522968
07/17/18 08:59 AM
07/17/18 08:59 AM
Tennessee
Hemi ragtop Offline
Hemi ragtop  Offline
Tennessee
My set up with the 540" HEMI is STOCK. The 26" radiator is even the correct part# for a 66'. Viscous fan, stock shroud and 180 degree thermostat. I also have the rubber "air dams" that the factory installed on the front and back of the hood. Driving in high 90's produces temps of 190-200 on the freeway at speed. As soon as I am on a back road, 45-55 mph, the temp comes down to 180-190. The factory knew what they were doing!
Re: What cools better [Re: dart440_72] #2522975
07/17/18 10:00 AM
07/17/18 10:00 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
I changed out the 440 source water pump to a mancini 6 blade with the anti-cavitation disc; reduced temps 15-20 degrees. I also use the hi-flow 160F thermostat. i'm still not where I want to be but was very surprised by a pump change.
Re: What cools better [Re: dart440_72] #2523088
07/17/18 03:12 PM
07/17/18 03:12 PM
an8sec70cuda Offline
I voted electric, b/c that's what I use. Then realized you asked which cools better...that'd be mechanical. I'm just not willing to take the power loss.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: What cools better [Re: lewtot184] #2523649
07/18/18 04:25 PM
07/18/18 04:25 PM
The Netherlands
The Netherlands
I've also found that the stock blade-type waterpumps seem to flow/cool better than the newer style scroll type waterpumps.
Perhaps the scroll type impeller needs to be spun faster before it becomes more efficient.
I'm sure someone has done a study about that somewhere in the (recent) past.
Re: What cools better [Re: dart440_72] #2523767
07/18/18 07:41 PM
07/18/18 07:41 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
My street car has a Becool aluminum radiator and a Spal dual fan set up with a shroud. fan is set of 200 and shits off at 175. Car never gets hot driving all over town. Engine makes 750ish HP on pump swill
