What cools better
#2522295
07/15/18 09:39 PM
07/15/18 09:39 PM
Posts: 314 Medina, OH
dart440_72
Medina, OH
I have battled cooling issues for long time. Recently, I saw a post about Champion radiators. People were praising them and how good they were. They said, " I can't get the car over 180* in 95* heat. I on the other hand have the exact opposite problem. So I have a poll before I switch to a Griffin radiator to give that a shot.
What do you use on the street? I'm not concerned about the track because that is a run then shutdown for cooling. I am looking for higher horsepower street driven cars. Mechanical fan and pump? Electric fans and electric pump, combo of both?
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
Re: What cools better
[Re: dart440_72]
#2522311
07/15/18 10:24 PM
07/15/18 10:24 PM
Posts: 2,469 Sydney,Australia
tex013
Sydney,Australia
I use a AfCO universal radiator , just had brackets tigged on and adjusted lower hose outlet angle
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: dart440_72]
#2522347
07/15/18 11:24 PM
07/15/18 11:24 PM
Posts: 2,871 Pattison Texas
CSK
Pattison Texas
512 ci, cold ac, driven in 105deg temps,runs 180 all day long, sitting in traffic or not, 2 row ECP rad, 18" 7 blade flexalite mechanical fan, 68 Charger so far runs 11.33 @ 121, just had the car weighed again, 4050 with me.
[Re: dart440_72]
#2522402
07/16/18 03:12 AM
07/16/18 03:12 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
The '71 Charger with 500" stroker is still running the stock 26" radiator with the Mopar Performance viscous fan package. I also have a pusher fan in front of the radiator, but mostly use it in the pits to cool the radiator with the engine off. Although this works, it is on the edge, and it temps do creep up on long drives when it is 90+ degrees out. My '69 Coronet 505" stroker had a Champion 26" 4-core radiator. Pretty good for the cost. With Mopar Performance viscous fan package, no problem cooling. With the Contour (Ford) dual cooling fans replacing mechanical fan, it still cooled good until I added A/C and the A/C condenser in front of the radiator. The extra heat load and reduced air flow from the A/C setup made that combination marginal in hot weather. I think mostly airflow related. I have switched to the Griffin Exact Fit radiator and Larger Spal 13" dual fans. I hope it cools better, but I have made other changes and have not driven the car with that setup yet. I also had a GlenRay HD Radiator with the mechanical setup, and it worked great, but when switching to the electric fan setup I did not want to mess up that radiator so I set it aside and installed the Champion. On the Champion radiators, I think in my setup the 3-core may have cooled as well or better than the 4-core because the 4-core is pretty thick and I think that partly reduced the air-flow through the radiator.
[Re: dart440_72]
#2522411
07/16/18 06:35 AM
07/16/18 06:35 AM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
How does the inside of your radiator look when looking through the cap-opening (w/ coolant drained a bit below the toplevel)? Are the channel-entries clean and open? A citric acid treatment cured overheating in a 496ci setup with stock 3-row radiator for me. The car still has a 1:1 crank:waterpump ratio, but it also has its stock 'narrow' steel shroud with a metal flex-fan partly inside. Engine has 10.5:1 CR, XR274-solid roller, Edelbrock heads. Before it had rust and scale-particles blocking the radiator channels and everything had a brownish color. After the first full day-soak in citric acid, the radiator metal already looked like new, aside from a few deposites near the channel-openings. After that I let it soak a few days more while occassionally tilting the radiator to agitate the acid inside.
[Re: dart440_72]
#2522425
07/16/18 09:19 AM
07/16/18 09:19 AM
dart440_72
Medina, OH
I'm running thermocure through it right now. However, it didn't look too bad inside. It seems like the common theme above is mechanical. I have a double electric fan with a shroud covering 95% of the radiator.
[Re: dart440_72]
#2522603
07/16/18 03:20 PM
07/16/18 03:20 PM
Posts: 571 Spring Hill Fl
65Fury440
Spring Hill Fl
Is there a source for a smaller water pump pulley?
I have a 7" single groove water pump pulley and a 5.75" crank pulley.
[Re: 65Fury440]
#2522605
07/16/18 03:33 PM
07/16/18 03:33 PM
Posts: 4,457 Washington
madscientist
Washington
I have a 7" single groove water pump pulley and a 5.75" crank pulley. You are turning the pump way too slow. That isn't even 1:1 unless the crank pulley is the smaller one.
[Re: madscientist]
#2522622
07/16/18 03:50 PM
07/16/18 03:50 PM
65Fury440
Spring Hill Fl
I have a 7" single groove water pump pulley and a 5.75" crank pulley. You are turning the pump way too slow. That isn't even 1:1 unless the crank pulley is the smaller one. Yes the crank pulley is smaller. My stock crank pulley was just a little over 6.5", didn't think it would matter a whole bunch. I looked at a few different vendors and don't see any overdriven water pump pulleys. That crank pulley was the only diameter Source had when I ordered a new one, my stock pulley had just a little tweak in it. I suppose I could look for a new crank pulley and throw this one in the spare parts box.
[Re: 65Fury440]
#2522695
07/16/18 06:18 PM
07/16/18 06:18 PM
Posts: 4,743 Moved to N.E. Tennessee
GomangoCuda
Decades ago we all bought the Morose aluminum underdrive pulleys to free up a few horsepower. Now that we have stroker kits and good heads we can easily make a lot more power and we are now digging through the junk pile where the spiders live to find the biggest crank pulley so that we can trade a few of those easy hp for some hard to find cooling. Funny how that works.
[Re: dart440_72]
#2523088
07/17/18 03:12 PM
07/17/18 03:12 PM
Posts: 13,382 Marion, South Carolina [><]
an8sec70cuda
I voted electric, b/c that's what I use. Then realized you asked which cools better...that'd be mechanical. I'm just not willing to take the power loss.
[Re: lewtot184]
#2523649
07/18/18 04:25 PM
07/18/18 04:25 PM
BigBlockMopar
The Netherlands
I changed out the 440 source water pump to a mancini 6 blade with the anti-cavitation disc; reduced temps 15-20 degrees. I also use the hi-flow 160F thermostat. i'm still not where I want to be but was very surprised by a pump change. I've also found that the stock blade-type waterpumps seem to flow/cool better than the newer style scroll type waterpumps. Perhaps the scroll type impeller needs to be spun faster before it becomes more efficient. I'm sure someone has done a study about that somewhere in the (recent) past.
[Re: dart440_72]
#2523767
07/18/18 07:41 PM
07/18/18 07:41 PM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
My street car has a Becool aluminum radiator and a Spal dual fan set up with a shroud. fan is set of 200 and shits off at 175. Car never gets hot driving all over town. Engine makes 750ish HP on pump swill
