Run Data Question - Engine RPM #2522050
07/15/18 10:15 AM
07/15/18 10:15 AM
HR3128 Offline OP
HR3128  Offline OP
Got out to the track for the first time this year last Wednesday for Test & Tune. Car ran good, no problems. Data for one of the runs is attached. On the graph, engine RPM is flat for about a second just after launch. Then climbs. I would expect to see some kind of RPM increase for the first second.
What do you think? Why is engine RPM flat for that time?
60 ft = 1.372, 1/8 mi = 6.312 et/107.68 MPH
93 Daytona, aprox 2600 lbs, Back-half, 4-link, 4.88 rear, Mild 377inch R3/W8, powerglide 1.76, 6K convertor
Re: Run Data Question - Engine RPM [Re: HR3128] #2522060
07/15/18 10:55 AM
07/15/18 10:55 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Looks like it spun a bit at the hit then dead hooked. Since it's flat at the same rpm it drops on the shift, I'd say the converter had it. Nothing weird about it. Just too much wheel speed for the motor to maintain.
As long as I'm flapping my gums, I'd offer this too. The motor looks like it pulls all the way up to 7200 or so where I'm guessing you're crossing the stripe. I'd loosen the converter, leave harder, and make the first shift at 7200 instead of 6500, or wherever you're shifting. I think it would go a good bit faster.
Just making that shift higher would help I think.
Re: Run Data Question - Engine RPM [Re: HR3128] #2522120
07/15/18 01:34 PM
07/15/18 01:34 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
We have found shifting 500 RPM over Peak horsepower with a Glide has been the fastest way down the track.. tuning the flat spot out of first gear is very difficult with a Glide.. do you know where you make Peak power and Peak torque..
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Run Data Question - Engine RPM [Re: WHITEDART] #2522172
07/15/18 03:40 PM
07/15/18 03:40 PM
HR3128 Offline OP
HR3128  Offline OP
I don't have peak HP or Torque numbers. I was thinking about putting it on a dyno but dropped it in the car instead. Left at 4800, shifted at 6800. Is a 1st gear flat spot typical for cars with a glide? I'll try leaving/shifting a little higher & see what it does.
Re: Run Data Question - Engine RPM [Re: HR3128] #2522197
07/15/18 04:29 PM
07/15/18 04:29 PM
AndyF Offline
AndyF  Offline
I can't see the data on my screen very well. Do you have a driveshaft speed sensor? If you have both engine rpm and driveshaft rpm then you can start to see what the transmission is doing.
Re: Run Data Question - Engine RPM [Re: HR3128] #2522200
07/15/18 04:37 PM
07/15/18 04:37 PM
Washington
madscientist Offline
Washington
I can't see it very well either. Damn glad I'm not the only one who is losing his vision.
Re: Run Data Question - Engine RPM [Re: HR3128] #2522209
07/15/18 04:57 PM
07/15/18 04:57 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I don't have an answer but I can tell you mine looks almost identical including the driveshaft rpm. Its a 727 3450 lbs runs 9.60's. Have not had time to investigate it - don't know if it started with the new carb or not. Have not looked at my old data yet.
Re: Run Data Question - Engine RPM [Re: HR3128] #2522217
07/15/18 05:24 PM
07/15/18 05:24 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
If you only have A.2 magnet pick up on the drive shaft that can be a normal look at the hit.. it can appear as wheel speed.. do you have the grid.. we add timing in the first gear where the converter is trying pull the motor down.. don't be afraid to add three or four degrees of timing for the first one to two seconds of the Run.. also adding timing at shift recovery will help ET as well
Re: Run Data Question - Engine RPM [Re: HR3128] #2522238
07/15/18 07:00 PM
07/15/18 07:00 PM
AndyF Offline
AndyF  Offline
Good idea. Perhaps upgrade to a 8 magnet setup on the driveshaft so you can get more resolution. I've seen some guys doing that are even more. There was also a setup where a guy was using the teeth on the parking brake in a 727 trans as a reluctor wheel for the driveshaft speed. That would provide some decent resolution since there are a lot of teeth on that wheel.
Re: Run Data Question - Engine RPM [Re: HR3128] #2522248
07/15/18 07:23 PM
07/15/18 07:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What is your stall on it.. looks low to me..
you need to be up in the revs to launch hard
wave
Re: Run Data Question - Engine RPM [Re: MR_P_BODY] #2522249
07/15/18 07:31 PM
07/15/18 07:31 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Looking at the data it flashes to 5900 and drops to 6000 at the shift.. so the actual stall speed is probably 6000.. he can probably get a few hundred RPM more out of it with timing.. I'm betting the converter is too tight.. but without Dyno sheets we will never know
Re: Run Data Question - Engine RPM [Re: WHITEDART] #2522259
07/15/18 07:54 PM
07/15/18 07:54 PM
HR3128 Offline OP
HR3128  Offline OP
Here's a bigger pic.
It is a 6K stall convertor. Not a Grid, older MSD Digital 7. I think timing could be adjusted per gear. I'll have to look at that.
Drive shaft sensor only gets 2 pulses per rev.
Re: Run Data Question - Engine RPM [Re: HR3128] #2522273
07/15/18 08:47 PM
07/15/18 08:47 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
The stall speed will drop for the same torque input as the vehicle starts moving. What you're seeing is normal. The converter torque multiplication changes as a function of the speed ratio of the converter (engine speed to turbine speed). The torque multiplication is dropping as it is no longer at true stall (0 turbine speed).
As Whitedart mentioned, adding timing will reduce the drop.
Re: Run Data Question - Engine RPM [Re: HR3128] #2522335
07/15/18 10:56 PM
07/15/18 10:56 PM
AndyF Offline
AndyF  Offline
Looks to me like the car doesn't start to move until the 1 second mark. Is that correct? So the first second of this data log is you sitting on the line with the engine at 5000 rpm? And then at the one second mark you release the brake and the engine speed goes up and the driveshaft speed starts to go up? If that is case then I guess I don't see an issue.
Re: Run Data Question - Engine RPM [Re: AndyF] #2522359
07/15/18 11:51 PM
07/15/18 11:51 PM
HR3128 Offline OP
HR3128  Offline OP
That's it exactly. First second is the car staged with rev limit at 4800, brake releases & engine RPM goes to convertor stall of 6000 RPM, driveshaft RPM goes up. It ran good, 6.31, 6.34 & 6.35 1/8 mile times, all at 107.xx MPH.
I just expected to see engine RPM climb after the brake release rather than sit at stall speed for a second.
Re: Run Data Question - Engine RPM [Re: HR3128] #2522370
07/16/18 12:14 AM
07/16/18 12:14 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If you release the brake and still sit there you
have a conv problem if there is no delay in it
wave
Re: Run Data Question - Engine RPM [Re: HR3128] #2522382
07/16/18 01:17 AM
07/16/18 01:17 AM
AndyF Offline
AndyF  Offline
I'm interested in what the little dip in the driveshaft speed is from. If the tires are spinning it seems like driveshaft speed would go up but about 1/2 second after you launch the driveshaft speed have a dip in it.
What are the other lines on the display? There is one that is steady across the top and one that goes up at launch and then goes down the rest of the time.
Re: Run Data Question - Engine RPM [Re: AndyF] #2522385
07/16/18 01:24 AM
07/16/18 01:24 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
The red line would be a g meter.. the line across the top is probably voltage it appears to be steady around 12 volts..
Re: Run Data Question - Engine RPM [Re: HR3128] #2522395
07/16/18 02:01 AM
07/16/18 02:01 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Pulled it right back to stall on the shift. It will go quicker upping the shift.
Re: Run Data Question - Engine RPM [Re: HR3128] #2522401
07/16/18 03:08 AM
07/16/18 03:08 AM
Cab_Burge Online work
Cab_Burge  Online Work
It looks like you have some tire spin between 1 second and two seconds on your chart, did you feel it? work
Does your car do a wheelie leaving the starting line? work
