E85 USE #2521551
07/13/18 06:48 PM
07/13/18 06:48 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
Other than a specific carb, what are the pro/cons/pitfalls.. of racing with e85? I know that e85 can be non standard at the pump, e80, e30....
Re: E85 USE [Re: A/MP] #2521568
07/13/18 07:23 PM
07/13/18 07:23 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
need screen style fuel filter...paper will dissolve
Tony
70 AARCuda Vitamin C
Re: E85 USE [Re: A/MP] #2521605
07/13/18 08:54 PM
07/13/18 08:54 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Make sure your Fuel system can handle the 25%+ in volume.
It starts a little sluggish in cool weather.
You need to be ABLE to tell your friends that have never ran it and think it is from the Devil to shut up and learn.
When the tune up is right spark plugs last a long time. Fuel burns clean
You MAY have to do more carb maint. because the fuel can adsorb moisture from the air.
Engine runs cooler and should be more consistent and have a bigger tuning window where it is happy.
"Just a Bracket car dressed up like a streetcar"
Re: E85 USE [Re: A/MP] #2521639
07/13/18 09:59 PM
07/13/18 09:59 PM
Mo.
racerx Offline
racerx  Offline
Mo.
I love it.
Re: E85 USE [Re: A/MP] #2521652
07/13/18 10:34 PM
07/13/18 10:34 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
30+ years ago I had an altered than ran on methanol. We ran and upper cylinder oil with the methanol. Same deal with e85? Very frequent oil changes?
Re: E85 USE [Re: A/MP] #2521655
07/13/18 10:42 PM
07/13/18 10:42 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
The guys that say this don’t know what they are talking about. Learn the secrets and straight alcohol is a breeze and a blessing. 165.00 a barrel, never having to cool down an engine, less battery drain, and more consistent. I make a pass and turn off my fan an water pump and open the lean out valve. Drive it back to the pits and wait till next round. Get heat in them and you will never have a moisture issue. I myself wouldn’t run E85 unless it was a street car too and I don’t have that issue.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: E85 USE [Re: A/MP] #2521664
07/13/18 11:29 PM
07/13/18 11:29 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
Do you need to get a bigger carb or stay with the same cfm as gas carb?
Re: E85 USE [Re: A/MP] #2521668
07/13/18 11:40 PM
07/13/18 11:40 PM
PA.
"Little"John
"Little"John
PA.
I took my 800 pump gas Holley off my engine and APD switched it over to alcohol for me
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: E85 USE [Re: A/MP] #2521670
07/13/18 11:49 PM
07/13/18 11:49 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
Found some misleading or confusing info. Alcohol and aluminum are not a good mix. Most modern electric fuel pumps are aluminum bodies and also the fuel filter canisters. Then there's the aluminum fuel cell and aluminum fuel lines. Ran alcohol in the moon tank of the altered with no issues that I remember. Was that the other benefit of the added lube?
Re: E85 USE [Re: A/MP] #2521738
07/14/18 10:13 AM
07/14/18 10:13 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
I use VP C85 instead of pump, and love it.
Most of the problems with pump 85 have been solved using the C85.
Has lube, and corrosion inhibitors in it, draws less water, and is consistently blended. Only down side is it's twice the cost of pump, but half the cost of a good race fuel.
Typically I burn less than a half gallon per pass accounting for warm up, and to and from the lines in total for the day.
Re: E85 USE [Re: A/MP] #2521742
07/14/18 10:31 AM
07/14/18 10:31 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
The only downside I personally have with it is that you can't let it sit for long periods. If you do it sort of creates this gel/goo build up. If you keep the fuel fresh/run the car often it's fine.
Mine has been on pump e85 for 7'ish years now. I don't even bother checking the % of the fuel anymore unless I'm really going to turn up the wick. Out of all the times I've ever checked the Alcohol %, it's only been off by more then 1% ONE time... (measured at 83%).
From my personal experience it's not as "non standard at the pump" as people would make you believe.
Re: E85 USE [Re: A/MP] #2521834
07/14/18 02:58 PM
07/14/18 02:58 PM
I've used pump E85 for over 5 ears now in my S/P car with a AJ modified and prepped carb., the first batch was winter mixed and tested to be E75 which required jetting down 3 let sizes to get the most power and torque on a DTS engine dyno wrench
All the other pump E85 I have bought since then has tested to be E85 out of the pump up
I use plastic 5.5 gallon fuel jugs and when they sit in the winter full to half full the fuel in the trailer they will test in the spring to be E87 to E89 work I bought around 16 gallons three weeks ago for $3.10 a gallon boogie
I was told that the gasoline evaporates out of those jugs making the alcohol content denser work confused
As far as consistency run to run from early morning to late afternoon at the track I love it boogie up
Re: E85 USE [Re: dthemi] #2521875
07/14/18 04:32 PM
07/14/18 04:32 PM
Mo.
racerx Offline
racerx  Offline
Mo.
was there any difference in performance using vp c85 over pump e-85?
Re: E85 USE [Re: racerx] #2521937
07/14/18 08:53 PM
07/14/18 08:53 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
I tested C85 on the dyno against pump. C85 was better top to bottom, and almost 5 percent better at peak. Jetting was higher with the C85. Went from 8 .144 jets to 8 150 jets. On 2 1250 dominators
C85 has MTBE and a few other oxidizers, one of which is one of the propanes.
Re: E85 USE [Re: A/MP] #2521986
07/15/18 12:41 AM
07/15/18 12:41 AM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
I’m on my second year of using it and love it. It has proven to be more consistent than race gas for me at a fraction of the cost. Get a good carb by someone that knows what they are doing and make sure your fuel supply system is up to the increased demand. I even let the fuel sit in my metal fuel tank over winter with zero rust or corrosion issues. Just added a little Lucas E85 stabilizer and all is well. I have not noticed any oil dilution either. Just make sure if you start the engine, always let it get over 170* before you kill it to vaporize the fuel. Takes a little getting used to, but is worth it in my opinion.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: E85 USE [Re: 71yelladustr] #2522288
07/15/18 09:32 PM
07/15/18 09:32 PM
Mo.
racerx Offline
racerx  Offline
Mo.
iagree this is what I do.
