Re: Gas tank question
[Re: CARMAN]
#2521627
07/13/18 09:39 PM
07/13/18 09:39 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
copper or aluminum sealing washer
[Re: CARMAN]
#2521800
07/14/18 01:37 PM
07/14/18 01:37 PM
Supercuda
About to go away
About to go away
up yours
Pipe thread wouldn't use a gasket.
[Re: CARMAN]
#2521811
07/14/18 02:12 PM
07/14/18 02:12 PM
Supercuda
About to go away
About to go away
up yours
Problem is compatibility. Some rubber falls apart in the presence of gasoline. I have no idea what those oil pan drain plug gaskets use.
[Re: CARMAN]
#2521881
07/14/18 05:05 PM
07/14/18 05:05 PM
Posts: 25,821 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I used a rubber O ring on my '56, don't remember the size but the slight recess in the tank skin made the O ring compress without oozing out the side of the plug.
[Re: CARMAN]
#2522265
07/15/18 08:29 PM
07/15/18 08:29 PM
Posts: 237 British Columbia, Canada
Old Ray
Just gotta measure the plug and get some that fit. OK, I have a '56 Plymouth (wagon) that I am changing to fuel injection, the old original tank has not had fuel in it for many years. I took the plug out today to see what kind of gasket was used. I used a 1/2 drive extension for the double hex plug. NO gasket, I am sure there is supposed to be one, it just had disintegrated. The OD of the threads is 7/8 inches. I think any nylon or copper gasket would work.
