Fault code P0520 #2498115
05/20/18 03:40 AM
05/20/18 03:40 AM
ND
dodgedon Offline OP
dodgedon  Offline OP
ND
2014 Chrysler town & country.
The engine light came on our van and we have this code P0520
Tried looking online and found its oil pressure sender issues or maybe oil temp?
Whats the deal with this? Any thoughts are greatly appreciated...Thank you!
67 Charger 383 auto
75 Dodge CNT 800 CAT Diesel
2012 Ram Crew cab 5.7 4x4
Re: Fault code P0520 [Re: dodgedon] #2498117
05/20/18 04:16 AM
05/20/18 04:16 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I had an oil pressure sender conk out....2007 Ram 1500. Easy job. The sender is near the oil filter.
Maybe you will have similar good luck.
Re: Fault code P0520 [Re: dodgedon] #2498125
05/20/18 08:24 AM
05/20/18 08:24 AM
Ringtown, Pa.
Dartsport540 Online boogie
Dartsport540  Online Boogie
Ringtown, Pa.
There is a technical service bulletin NUMBER: 18-034-14 REV. A
. For oil pressure sending unit. Is it still under warrenty? Dealer should replace it if it is.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: Fault code P0520 [Re: Dartsport540] #2498294
05/20/18 05:00 PM
05/20/18 05:00 PM
ND
dodgedon Offline OP
dodgedon  Offline OP
ND
What is "Normal" on the 3.6 Wife's van, I drove it today about an hour and pressure started out about 96psi and was still in the high 60's at my destination. At about 179 oil temp.
67 Charger 383 auto
Re: Fault code P0520 [Re: dodgedon] #2498464
05/21/18 12:34 AM
05/21/18 12:34 AM
S.E. Minnesota
gtsdude Offline
gtsdude  Offline
S.E. Minnesota
That seems high for oil pressure. My wifes 15 journey with 3.6 is about 70 at start up, after warm up it idles about 30 psi, in the 50's while driving.
Re: Fault code P0520 [Re: gtsdude] #2498904
05/22/18 02:11 AM
05/22/18 02:11 AM
ND
dodgedon Offline OP
dodgedon  Offline OP
ND
I agree it seems really high. It must be a sender issue giving false or over spec readings. I will look into it. It may also be under warranty still. Only has 60,000 miles on it. I will post back when i have an answer for it.
67 Charger 383 auto
Re: Fault code P0520 [Re: dodgedon] #2498939
05/22/18 08:57 AM
05/22/18 08:57 AM
Cleveland Ohio
sportfury70 Offline
sportfury70  Offline
Cleveland Ohio
My 2014 van oil pressure is 96 also at start up & idiling. It does not climb any higher than that when rpms go up.
Re: Fault code P0520 [Re: sportfury70] #2499314
05/23/18 01:34 AM
05/23/18 01:34 AM
ND
dodgedon Offline OP
dodgedon  Offline OP
ND
Thank you that's good to know. I would have never guessed that a little V6 would pump that much oil pressure stock...
67 Charger 383 auto
Re: Fault code P0520 [Re: dodgedon] #2499361
05/23/18 08:47 AM
05/23/18 08:47 AM
Cleveland Ohio
sportfury70 Offline
sportfury70  Offline
Cleveland Ohio
Oil pressure certainly surprised me too. Been that way since day 1 and nearly 70,000 miles.
Re: Fault code P0520 [Re: dodgedon] #2520942
07/12/18 10:44 AM
07/12/18 10:44 AM
ND
dodgedon Offline OP
dodgedon  Offline OP
ND
just a quick update. I replaced the sender. Took about 15 minutes. We drove it a few times and the light turned off on its own.
67 Charger 383 auto
