Wing Car Experts #2520798
07/11/18 11:51 PM
07/11/18 11:51 PM
A727Tflite Online content OP
A727Tflite  Online Content OP
Does this appear to be the factory A post molding - to you wing car experts?
Re: Wing Car Experts [Re: A727Tflite] #2520879
07/12/18 02:55 AM
07/12/18 02:55 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I would say yes, if it's a repro it's been detailed very well, but seeing how it has the slightly "beaded/rolled" bottom edge, I'd say it's most likely original, whatever tool the original OEM vendor used to trim/shear off the bottom ends usually resulted in the bottom edge having a somewhat "beaded" edge, or shadow crease/slight roll over from the cutting process ...something you won't see in the repros.
Mike
Re: Wing Car Experts [Re: DAYCLONA] #2520882
07/12/18 03:27 AM
07/12/18 03:27 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Also the A pillar screw retainer area looks original in it's detail, something lacking in the repros, most often the repros don't even have no holes for Bird installation, and the current vendors and end users haven't the time/effort/tooling/knowledge/etc to bother with this detail...
Re: Wing Car Experts [Re: DAYCLONA] #2520885
07/12/18 03:44 AM
07/12/18 03:44 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Here's a "repro".... bad one at that
Re: Wing Car Experts [Re: A727Tflite] #2521079
07/12/18 03:51 PM
07/12/18 03:51 PM
Thanks Dayclona, Great info.
Another question - what material is the rear spoiler made of and what are the vertical supports made of?
Re: Wing Car Experts [Re: A727Tflite] #2521105
07/12/18 05:00 PM
07/12/18 05:00 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Aluminum all 3 pcs, the aluminum sides/uprights are sand cast, and the center blade is a continuous cast extrusion of aluminum
Re: Wing Car Experts [Re: A727Tflite] #2521156
07/12/18 07:30 PM
07/12/18 07:30 PM
Thanks again.
