Re: dot 5 brake fluid
[Re: mopars4ever]
#2520806
07/12/18 12:13 AM
07/12/18 12:13 AM
Posts: 7,538 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
My cars are a mix of DOT 3, 3-4 and 5. Each one works just fine with the OEM fluid they came with. Just use it consistently, keep it refreshed and don't mix.
- The '67 Satellite is driven in regular passenger street conditions on DOT 3, and is just fine. - The '82 Alfa Romeo track racer is abusive on brakes and bearings, but never had an issue on factory spec DOT 3-4. - The '65 Satellite was restored and converted to a two-circuit MC for regular street use. I put DOT 5 in it from the get-go, I'm thankful I made the choice, cuz I spilled some on the paint and it didn't eat into it. The only issue I had with the brake feel was traced it to the automatic brake shoe advancers not working properly on the front. It wasn't the DOT 5.
Cheers, - Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
[Re: Gavin]
#2520921
07/12/18 09:40 AM
07/12/18 09:40 AM
Posts: 5,459 Michigan
oldjonny
Don't argue with me.
I originally re-did my 1967 Barracuda in 1980 and put DOT 5 in it. Still in it today. Just finishing up a '66 coronet disc brake conversion and DOT 5 went right into that as well (from the same jug that I bought in 1980).
No issues, no horror stories (and no gunked up an plugged lines)
Never, ever argue with an IDIOT. They will drag you to their level and then beat you with their years of experience
[Re: oldjonny]
#2520953
07/12/18 11:11 AM
07/12/18 11:11 AM
Posts: 19,408 north of coder
moparx
in my experience with bleeding brakes, no matter what fluid is used, the most common problem with not being able to get all the air out of the system [not counting upside down calipers] comes from guys pumping the living wizz out of the pedal before cracking the bleeder. this will cause foaming of the fluid. if a guy just lightly pushes down, open the bleeder, close the bleeder, release the pedal, no foaming happens. rinse and repeat a couple of times, done. if by yourself, lightly crack bleeder, put a tight fitting hose on the bleeder, then submerge the hose into a jar or can with clean fluid. lightly stroke pedal, rince, repeat several times per wheel, done. this has worked for me for many, many, years.
[Re: Gavin]
#2520969
07/12/18 12:00 PM
07/12/18 12:00 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Still seems to be some misinformation. My understanding on this very well-worn topic was that DOT5 absolutely is mixable with DOT3 or 4, since that is a legal requirement for any brake fluid. But just because you can, why would you - it costs more, and you wouldn't get the benefits like it being kind to paint etc. Also, it's common to find the brakes a bit more difficult to bleed (i.e. start with a slightly more spongy pedal), but once properly bled should be absolutely fine. DOT 5.1 is often confused with DOT 5, DOT 5 is NOT COMPATIBLE with anything, DOT 5.1 however is...
[Re: lewtot184]
#2521025
07/12/18 01:56 PM
07/12/18 01:56 PM
Posts: 25,812 Rio Linda, CA
John_Kunkel
Rio Linda, CA
dot 5 will not mix with dot 3 or dot 4. they separate out kind of like vinegar and oil salad dressing. don't believe me? put both in a container together and see what happens. True dat but so what?
[Re: DAYCLONA]
#2521031
07/12/18 02:07 PM
07/12/18 02:07 PM
John_Kunkel
Rio Linda, CA
DOT 5.1 is often confused with DOT 5, DOT 5 is NOT COMPATIBLE with anything, That's simply not true and that chart is somebody's wet dream. The definition of "compatible" is two things able to exist or occur together without conflict.As stated earlier, in order to receive DOT approval, all brake fluids must be able to coexist in the same system with no ill effects.
[Re: John_Kunkel]
#2521052
07/12/18 03:06 PM
07/12/18 03:06 PM
Posts: 18,157 Mass
DAYCLONA
Mass
DOT 5.1 is often confused with DOT 5, DOT 5 is NOT COMPATIBLE with anything, That's simply not true and that chart is somebody's wet dream. The definition of "compatible" is two things able to exist or occur together without conflict.As stated earlier, in order to receive DOT approval, all brake fluids must be able to coexist in the same system with no ill effects. Sure... you could add salad dressing and mineral spirits along with DOT3/4 and DOT5 if you wanted to, but would you want that in your system? Whom am I to believe?, you or the brake/brake fluid manufacturer(s)? Make me a believer, some me some data on DOT5 and DOT3/4 mixed in the same system with no "ill effects"... mechanical effects, not chemical...
[Re: gtx6970]
#2521062
07/12/18 03:20 PM
07/12/18 03:20 PM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
Ive put dot5 in 5 or 6 cars with not one single issue.
Buddy of mine put it in his 1955 Chrysler 300 and had nothing but problems with it.
He had the master cyl rebuilt by WhitePost I think. they rebuilt it 2 or 3 times , finally told him drain and flush it out replace with dot3 or warranty was void. he hasnt had a problem since Have used in my 56 300 B since restoration in 1986. Zero issues outside of normal lousy standard 1956 drum brake performance. Good for one panic stop or less at 60 mph. What is worse than standard drum brakes is the fact of only one reservoir for both front and rear brakes. Dot 5 is worth the price of admission if for no other reason is that it will not damage your concour paint job if you blow a hose or spill on paint.
[Re: DAYCLONA]
#2521148
07/12/18 07:05 PM
07/12/18 07:05 PM
John_Kunkel
Rio Linda, CA
Whom am I to believe?, you or the brake/brake fluid manufacturer? Keep in mind that the disclaimers are written by lawyers, not engineers.
[Re: mopars4ever]
#2521214
07/12/18 09:22 PM
07/12/18 09:22 PM
Posts: 1,212 Minn
SportF
Minn
Update: It was the master cylinder that was bad. I put a new one on and the pedal feels like it should now. Thanks for the help. Glad you got your problem fixed. Now, do you see why I love this topic?
[Re: Brewzer67]
#2521297
07/13/18 01:06 AM
07/13/18 01:06 AM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I'm sorry. I live in Wisc as well. How does moisture get in your lines? I have never had that problem. My junk gets normal maintenance at best. Likely not what they should. I have a couple 70's trucks I drive year round with zero brake fluid issues. I am lazy about maintenance with these trucks and use the cheapest crap on the shelf, in the system. The original lines lasted several decades and I expect them to do it again.
I have mechanical Aptitude. I can screw up anything.
[Re: mopars4ever]
#2521374
07/13/18 10:07 AM
07/13/18 10:07 AM
Posts: 1,756 London, England
Gavin
London, England
I've not seen anything to make me change my mind on what I stated. It's a legal requirement for all DOT brake fluids to be able to mix. but you wouldn't want to because you lose the extra benefits you are paying for, so no surprise that the vendors say do not mix - they don't want you paying extra then still finding problems. (I'm sure they wouldn't mind selling larger quantities either!)
Surprised E-Berg has not chipped in:
Tech Question Gary Boak, Chilliwack, BC, Canada, 1969 Dart Swinger 340
I notice in the April 04 issue you say that DOT 5 brake fluid can be used without flushing the system. Everything I have heard and read states that Dot 5 does not mix with anything except DOT 5. When switching to DOT 5 are you not supposed to use new rubber?
Gary-
Another old wive's (or Mopar Muscle) tale. First, realize that DOT specs don't specify the composition of the fluid, the rating relates only to the boiling point. So, therefore, it would be possible to have DOT 3 fluid that's silicone, and DOT 5 that's not (and this latter combination does exist.) These specs are covered in detail in Federal Motor Vehicle Safety Standard section number 571.116, which is part of the Code of Federal Regulations, #49, Chapter V, see for yourself at:
Code of Federal Regulations, #49, Chapter V Here's an excerpt from the law on boiling points:
Equilibrium reflu point (ERBP). When brake fluid is tested according to S6.1, the ERBP shall not be less than the following value for the grade indicated:
(a) DOT 3: 205 ÌŠC. (401 ÌŠF.).
(b) DOT 4: 230 ÌŠC. (446 ÌŠF.).
(c) DOT 5: 260 ÌŠC. (500 ÌŠF.).
A recent change to the law specifies that non-silicone fluid meeting DOT 5 temperature specs. be labeled DOT 5.1. All DOT 5 fluid must be purple in color, all other grades must be clear to amber.
The baziilion pages of the specs relate mostly to boiling points, viscosity, and the fluid's effects on rubber (swelling), as well as testing procedures. But there's also much written about compatibility. What has probably caused the confusion is that DOT 5 fluids are tested differently than other types, but these tests apply equally to silicone and non-silicone fluids. Subchapter S6.5.4 addresses miscibilty, specifying that the fluid being tested must mix with a standard type fluid, and this miscibilty test DOES apply to DOT 5 fluids, and can't gel, swll cups, etc. when mixed. So there!
The Society of Automotive Engineers (SAE) also has detailed specs: J1703 and J1705.
It's true that much has be written saying that silicone based fluids cannot or should no be mixed with other types, this is that old myth-perpetuating deal. Nowhere can I find a scientific study or analysis to back this story up - do a Google search yourself if you don't trust me.. There's only been two studies on this that I'm aware of: Dow-Corning, the leader in silicone brake fluids (possibly the only true USA manufacturer), did a detailed study almost 30 years ago, wherein a system was haphazardly swapped from DOT 3 to silicone, with the intent of leaving a significant portion of the fluid UNchanged. The system passed all DOT tests easily. The second test is less scientific, but, to me, more significant: Yours truly has been using DOT 5 silicone in every car I've owned or serviced since approx. 1978. I have never flushed a system! I have, in some cases, bled out most of the old stuff, in other cases, I've just topped up a DOT 3-filled system with silicone. Cars serviced by me in this fashion have stopped will from speeds over 160 MPH. I've never had a stuck caliper (or wheel cylinder) pistion since making this change universal in my fleet - even in cars stored for long periods. I've also never damaged pain from a brake fluid spill. Come to my garage - you will find 4 or 5 bottles of DOT 5 silicone, and zero of DOT 3 or 4.
On your Dart, do what I do (and say): bleed out as much of the old garbage as you can, until you see purple at each bleeder screw. And don't worry about it!
End of story.
Rick Ehrenberg
