PT Cruiser - door panel removal? #251919
03/12/09 07:55 PM
03/12/09 07:55 PM
Aurora, Oh.
max_maniac Offline OP
Aurora, Oh.
The rear drivers side window on the wife's PT will not go up. I can hear a clicking noise inside the door panel when hitting the window button but nothing is moving. I remooved 2 scres from the grab handle and 2 screws from the door panels but this thing will not budge. Whats the trick for removal? I'm stumped. Thanks for any help.
Russ
Re: PT Cruiser - door panel removal? [Re: max_maniac] #251920
03/12/09 09:47 PM
03/12/09 09:47 PM
I can't vouch for the rears, but the front panels really fit tight to the metal, so once you get the screws out (and in front there is one hidden behind the mirror mount moulding) you start at the bottom rear, get a putty knife under the panel and gently pry outward. Put duct tape on the metal to avoid scratching or be very careful.
The panels are held on with the usual plastic barrel plugs as I recall.
Hope this helps.
Re: PT Cruiser - door panel removal? #251921
03/12/09 10:45 PM
03/12/09 10:45 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Here's a great place for PT questions to get answered. http://www.ptcrew.com/index.php?msg=1&sid=0879a3c7e34041c623172961e2f59579
