3rd member torque question #251719
03/12/09 02:20 PM
03/12/09 02:20 PM
own private Idaho
N
ngpSatellite Offline OP
N
own private Idaho
swaping out a differential this weekend and my question is..... do you torque them down to a specific torque or just crank the nut down as tight as possible??..... I don't want it to leak
Re: 3rd member torque question [Re: ngpSatellite] #251720
03/12/09 02:28 PM
03/12/09 02:28 PM
The spec is 45 ft lbs but 1st make sure the 3rd member is seated all the way around & do tighten in a crisscrossing pattern so it pulls down even
Re: 3rd member torque question [Re: RapidRobert] #251721
03/12/09 02:34 PM
03/12/09 02:34 PM
own private Idaho
N
N
own private Idaho
Thanks Robert
Re: 3rd member torque question [Re: ngpSatellite] #251722
03/12/09 02:49 PM
03/12/09 02:49 PM
you're welcome bro. What ya using for gasketing? I like a felpro gaskset with some chassis grease on both sides of it. It seals good(there's no real pressure there) & if I do alot of gear swapping it is reuseable & cleaning RTV from around each & every one of those studs is a REAL PAIN
Re: 3rd member torque question [Re: RapidRobert] #251723
03/12/09 04:46 PM
03/12/09 04:46 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I use RTV. No leaks ever. To get the old stuff off the threads just use a rag like you were polishing your shoes. Takes the stuff right off.
