Re: no oil up top
[Re: PS Arrow]
#251607
03/12/09 12:03 PM
03/12/09 12:03 PM
Posts: 52,972 Romeo MI
MR_P_BODY
There is only a couple of things to check... slowly rotate the crank, if nothing then check to make sure the rocker shaft isnt upside down, if correct the check the cam bearings arent in wrong(hole not lined up). Of course you could have a bad gasket that the holes arent in it for the oil passage
Re: no oil up top
[Re: go green]
#251610
03/12/09 06:51 PM
03/12/09 06:51 PM
Posts: 8,165 Left Coast
BobR
Left Coast
I'm thinking cam bearing also.
Like was said, you have to turn the motor over while priming if you don't use Cab's cam bearings. If you aren't doing this then you will not likely get any oil to either side. This is Mopar 101, people.
Re: no oil up top
[Re: MR_P_BODY]
#251611
03/12/09 07:00 PM
03/12/09 07:00 PM
Posts: 6,293 Northeast, Alpine, NY
9 Sec Phill
On a road near you
On a road near you
