Re: Low comp 440
[Re: cudaman1969]
#2513554
06/26/18 04:54 PM
06/26/18 04:54 PM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
Years ago I ran the.509 cam in a 67 coronet rt with 10.1 440, 3800 converter and 4.10s and it ran 12.0 on street tires. Prior to that in a 67 gtx with a 9.1 440, 3000 stall and 3.23's and man was it a slug! Barely broke 13's on street tires, and not like the tires were spinning. I don't think the 509 likes low compression, or numerically low gears, but should work well with the 4 speed and if you have 3.91's or higher. Otherwise maybe a step or two smaller might be a better fit.
2 kids and a dog
Re: Low comp 440
[Re: cudaman1969]
#2513591
06/26/18 06:05 PM
06/26/18 06:05 PM
Posts: 427 Sweden
Mopar Guy
Sweden
The reason I'm asking is I had read before about some cam company who makes a cam for these low comp engines with a radical sound. Can't remember witch one, just looking for feedback if someone had used one and had results. When a race car it would stop pulling at 5000, this same cam in my 383 HC, would go 7000 easy, still pulling. Cam is over 40 years old. Cams should be better now. This is probably what you are talking about !? http://www.hughesengines.com/Index/produ...mp;partid=30173
Re: Low comp 440
[Re: cudaman1969]
#2513600
06/26/18 06:14 PM
06/26/18 06:14 PM
Posts: 14,504 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Put the smallest of the Howard’s Rattlers in it.
Or the 703 VooDoo cam.
Re: Low comp 440
[Re: cudaman1969]
#2513610
06/26/18 06:33 PM
06/26/18 06:33 PM
Thumperdart
State of confusion
The reason I'm asking is I had read before about some cam company who makes a cam for these low comp engines with a radical sound. Can't remember witch one, just looking for feedback if someone had used one and had results. When a race car it would stop pulling at 5000, this same cam in my 383 HC, would go 7000 easy, still pulling. Cam is over 40 years old. Cams should be better now. Comp Voo Doo series fit that bill and I've seen em run good as well..........
Re: Low comp 440
[Re: cudaman1969]
#2513658
06/26/18 09:30 PM
06/26/18 09:30 PM
Posts: 4,209 New York
polyspheric
New York
IMHO the "necessity" of running X:1 static CR with Y intake closing is just advice. Ford, Hudson, and Harley-Davidson flatheads ran extremely low CR and long cams for many decades. It does mean that you need more attention to axle ration, crawl ratio (1st gear X axle), stall speed, initial advance etc. because you know low speed response and power will be a bit soft with that combination (low CR + 509).
Boffin Emeritus
Re: Low comp 440
[Re: polyspheric]
#2513685
06/26/18 10:42 PM
06/26/18 10:42 PM
Posts: 8,285 fredericksburg,va
cudaman1969
fredericksburg,va
IMHO the "necessity" of running X:1 static CR with Y intake closing is just advice. Ford, Hudson, and Harley-Davidson flatheads ran extremely low CR and long cams for many decades. It does mean that you need more attention to axle ration, crawl ratio (1st gear X axle), stall speed, initial advance etc. because you know low speed response and power will be a bit soft with that combination (low CR + 509). I think I see what you mean, in race mode I had a 4.88 gear and a TA 3800 vert, 14/32 slicks. 1.5 - 60 and 7.58 1/8 mile, all steel 64 Savoy. Like I said it would flatten out at 5000. Grill ain't crooked, just the way pic was taken.
Re: Low comp 440
[Re: Dave Hall]
#2513694
06/26/18 11:01 PM
06/26/18 11:01 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
It will be fine with a 4 speed. Send it! I ran a 509 with an 8 to 1 '78 440 and a 3.55 gear in my car and it ran pretty good 12.54 with all junkyard second hand parts I had a whole bunch of fun that summer back in 1991. That cam works good with a 4-speed because you can leave at 4500 without any bog issues Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: Low comp 440
[Re: cudaman1969]
#2513789
06/27/18 07:51 AM
06/27/18 07:51 AM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
My old 440 was 9.2-1 with '516 heads M1 intake, 750 Carter, 509 cam, TA 10" convertor and 4.56 gears. It ran 12.19@106 in my old truck. If you are going to run the low compression, the 509 cam too make sure you have lots of convertor and gear.
Re: Low comp 440
[Re: cudaman1969]
#2513830
06/27/18 11:30 AM
06/27/18 11:30 AM
fast68plymouth
So. Burlington, Vt.
I’d have no problem running the 509 cam in an 8:1 440...... in a street/strip car with plenty of gear and stall if the emphasis was on the “strip” side of the build.
But if it’s more of a street car that might see the occasional trip to the track, I think are way better choices out there.
Re: Low comp 440
[Re: cudaman1969]
#2513875
06/27/18 01:04 PM
06/27/18 01:04 PM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
In the old DC Engine book they ran most of there cams in a 400 low cr A body back to back giving ETs for comparison.
I have a 9.5 452 that I put together in the late 80s strate out of the mopar books with pocket ported 452 heads and the 557 mopar mec cam. I recently came up with all the parts freshened up the heads and reassembled with a cam I had and the old dog made 520 hp and 545 tq., its basically a stock blueprinted 440. Back in the day I ran this motor with a little more cam and a Turbo Action 3800 converter, 4.88 gears @ 4400lbs for 11.50s.
Have a great day Iowan
"obsolete is neat"
