1971 340 block numbers questions #2512380
06/23/18 11:33 PM
06/23/18 11:33 PM
Akron, ohio
76orangewagon Offline OP
Akron, ohio
I have been looking for a date correct 1971 block for my SPD April 30th 1971 Cuda. My buddy from Pennsylvania sent me pictures today of a 1971 block that he has... the casting number was definitely in the ball park for a Mounds Rd engine including hints of the Corporate Blue paint but when I asked him for the numbers under the numbers below the #1 cylinder, this is what he sent me. Can anyone here help me decode the Two lines, it looks like the first line has light stamped 3,6,8's or 0 and then a 2 on the first line and the second line reads MH 340 R (Regular Fuel) or P (premium Fuel)I believe, MH could be M=Mounds Rd and the H would be 1972 assembly but usually the year proceeds the plant from my experience, like GM for 71 Mounds Rd or FW for 1970 Windsor. The last Picture is the current May 1st 1970 engine I currently have for the car which looks nothing like his block numbers.
Re: 1971 340 block numbers questions [Re: 76orangewagon] #2512381
06/23/18 11:39 PM
06/23/18 11:39 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Looks like a 1972 engine, what is the VIN# stamping on it? Your 71 should have an assembly number starting with GM340 (1971 Mound Road) or GW340 (1971 Windsor). Being a later SPD it was most likely a GM340
Re: 1971 340 block numbers questions [Re: ScottSmith_Harms] #2512393
06/23/18 11:57 PM
06/23/18 11:57 PM
Akron, ohio
Akron, ohio
Scott,
I'll have to get the Vin from him. I assumed its a 72 built engine but the January 1971 casting date thru me off along with the multiple stampings and dual lines. I'm trying to find a date correct block for my 71' April 30 build just coming up short everywhere. You built me the correct carb and I also have the correct exhaust manifolds, distributor, alternator..ect
Re: 1971 340 block numbers questions [Re: 76orangewagon] #2512396
06/24/18 12:08 AM
06/24/18 12:08 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yea, the Mound Road blocks seem to be fewer and further between, I've seen 10 GW blocks for every GM I've seen. Casting dates to build dates varied a bunch, most were 2 weeks to a couple months a part but there were much bigger gaps sometimes so you never know.
Re: 1971 340 block numbers questions [Re: 76orangewagon] #2512399
06/24/18 12:12 AM
06/24/18 12:12 AM
WV
Little Detroit Offline
WV
what is the order # on your fender tag?
Re: 1971 340 block numbers questions [Re: Little Detroit] #2512404
06/24/18 12:22 AM
06/24/18 12:22 AM
Akron, ohio
Akron, ohio
430 E35280
Re: 1971 340 block numbers questions [Re: 76orangewagon] #2512408
06/24/18 12:27 AM
06/24/18 12:27 AM
Akron, ohio
Akron, ohio
Since I am looking for a date correct block would it be to far off to use since it's a January 1971 Mounds Rd casting. Once painted all that would be visible is the casting date not the final assembly date. I would like to build a date correct 340 with lighter forged pistons and connecting rods and since the heads are X heads I'm looking to build a set of "J" heads which would be correct for the 71' year build. I have a great running May 1st, 1970 engine and I am not looking forward to spending more money for changes that the majority of people will never even notice but I feel the car is worth the effort .
Re: 1971 340 block numbers questions [Re: 76orangewagon] #2512448
06/24/18 03:21 AM
06/24/18 03:21 AM
Myrtle Beach, SC formerly the ...
340wedge Offline
340wedge  Offline
My Hamtramck 1971 Duster 340 engine has a date of 1-19-71 on it and is Corporate Blue. The car has a SPD of 07/09.
1971 Sassy Grass Green Duster 340
2006 Charger Daytona GoMango
Re: 1971 340 block numbers questions [Re: 76orangewagon] #2512563
06/24/18 01:21 PM
06/24/18 01:21 PM
MO
cdp Offline
cdp  Offline
MO
I have a late 71 block with a 71 VIN, standard bore. Never was sure of the application or assembly date, or if it was A or E-body.
VIN: 1B4525**
1-27-71 cast date.
Re: 1971 340 block numbers questions [Re: cdp] #2512601
06/24/18 02:12 PM
06/24/18 02:12 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
3528 = March 26, 1971. Most cars had assembly dated engines closer to the SPD of the car but there are no solid rules on that. So, as a replacement it would be fine for your car.
Re: 1971 340 block numbers questions [Re: cdp] #2512645
06/24/18 03:52 PM
06/24/18 03:52 PM
340wedge Offline
340wedge  Offline
VIN: 1B4525**
1-27-71 cast date.
That is interesting and makes sense. My 1-19-71 block is matching numbers and my VIN: 1B452494
