77 D100 Manual steering to power steering column question #2511507
06/21/18 10:19 PM
06/21/18 10:19 PM
Indiana
68_661charger Offline OP
Indiana
Might go power steering on the D100. Is the column the same between manual and power steering on a 77 D100? What about the extention shaft between the rag joint and the box? Also, what columns are bolt in to a 77?
Re: 77 D100 Manual steering to power steering column question [Re: 68_661charger] #2511624
06/22/18 07:51 AM
06/22/18 07:51 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
The lower shaft is different length. Check Borgeson for a replacement shaft. Iirc theirs are adjustable.
Angry white pureblood male
Re: 77 D100 Manual steering to power steering column question [Re: 68_661charger] #2511953
06/22/18 11:11 PM
06/22/18 11:11 PM
Indiana
Indiana
I looked again and the lower extension shaft as I put it is actually the manual box shaft with the rag joint bolted to the end then column. So the columns are the same I just need a box and a pump?
