Rear Drums slowly locking up when driving #2510082
06/18/18 06:09 PM
06/18/18 06:09 PM
NW New Jersey
RSI700VIPER Offline OP
NW New Jersey
Just started driving my 1970 440-4BBL Challenger and discovered I have a rear drum brake issue. The brakes worked fine for about 8-10 miles, then I noticed the engine was laboring when I was pulling into my driveway. I barely made it to the garage door when the rear drums locked up. I could smell brake lining material, and check the rear drum temps with an infrared lazer gun and one drum was 290 degrees and the other was 310 degrees.
I figured is was an adjuster issue and let the car sit overnight. The next morning, I was able to roll the car easily with just the push of my hand. Took it out for another test ride and the problem happened all over again. My guess is that it is a hydraulic issue, and that the brake pressure slowly bleeds off from the wheel cylinders. The car is new to me so I don't have the history but it looks like it has a new Master cyl.
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5
1969 Daytona Charger 440 4-Speed, Dana, EV2
1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7
1970 340 Six Pack Callenger T/A 4-speed T8 Tan
1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth
1969 Talladega Torino, 428CJ
1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
Re: Rear Drums slowly locking up when driving [Re: RSI700VIPER] #2510086
06/18/18 06:30 PM
06/18/18 06:30 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Pushrod too tight in the MC.
Needs to have a little play to grow with heat.
Re: Rear Drums slowly locking up when driving [Re: RSI700VIPER] #2510092
06/18/18 06:45 PM
06/18/18 06:45 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
internally collapsed rubber line that feeds the rear. Best bet is to loosen a rear bleeder after the brakes start to drag to see if it's a hydraulic issue.
Re: Rear Drums slowly locking up when driving [Re: stumpy] #2510127
06/18/18 08:22 PM
06/18/18 08:22 PM
^^^ What Stump said & there just was a comprehensive thread on a pretty much identical situation (2 long shoes on one side iirc).
Re: Rear Drums slowly locking up when driving [Re: RSI700VIPER] #2510128
06/18/18 08:24 PM
06/18/18 08:24 PM
IL us
I
ink Offline
ink  Offline
I
IL us
^^^^^^^^^^^^^^^^^ x3
Re: Rear Drums slowly locking up when driving [Re: RSI700VIPER] #2510191
06/18/18 10:45 PM
06/18/18 10:45 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
A little more involved but, crack ableeder loose and see if the brakes release. If so it's a hydraulic problem.
Get it to do it again, crack the rear line loose at the master. Do brakes release? If so problem it s master or booster related. If not then hose, line or p valve related. Duplicate symptoms and crack line at various places, note the results.
Angry white pureblood male
Re: Rear Drums slowly locking up when driving [Re: RSI700VIPER] #2510198
06/18/18 10:55 PM
06/18/18 10:55 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Just went through this with a friend...
JUNK 'aftermarket' proportioning valve...
Locating and installing an OEM valve solved the problem...
Re: Rear Drums slowly locking up when driving [Re: ruderunner] #2510209
06/18/18 11:19 PM
06/18/18 11:19 PM
NW New Jersey
NW New Jersey
This seems to be a good approach. I will try and report back. The proportioning valve is stock and original but the MC is aftermarket...
Re: Rear Drums slowly locking up when driving [Re: RSI700VIPER] #2510541
06/19/18 10:07 PM
06/19/18 10:07 PM
kalispell montana
jwilson 61 Offline
jwilson 61  Offline
kalispell montana
Water in the brake fluid will cause this also, as the boiling point isn't as high as brake fluid and it expands when hot, brake fluid being hygroscopic absorbs water over time so needs to be changed at times to keep rust out of the system and things working correctly.
70 cuda 440 6bbl Auto with a dana 60
68 road runner QQ1 383 auto
1970 6 barrel 4 speed Superbird FY1 number matching
15 Challenger 6.4 SRT pearl White 6 Speed
72 Cuda 440 5 speed
71 Road Runner 440 4 speed
Re: Rear Drums slowly locking up when driving [Re: RSI700VIPER] #2510693
06/20/18 09:38 AM
06/20/18 09:38 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Seems no one has said if it has self adjusters to check them.If backwards the brakes will adjust up everytime you use them going forward.Rocky
Chrysler Firepower
Re: Rear Drums slowly locking up when driving [Re: therocks] #2510720
06/20/18 11:16 AM
06/20/18 11:16 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Except they don't unadjust when sitting overnight
Don't be the exception.
Re: Rear Drums slowly locking up when driving [Re: therocks] #2511024
06/20/18 08:21 PM
06/20/18 08:21 PM
kalispell montana
jwilson 61 Offline
jwilson 61  Offline
kalispell montana
But they are released once they cool off, Adjusters will stay tight ..
72 Cuda 440 5 speed
Re: Rear Drums slowly locking up when driving [Re: jwilson 61] #2511182
06/21/18 02:04 AM
06/21/18 02:04 AM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
sounds like they are adjusted a little to tight and drag a little,the more you drive the more they heat and drag,when they cool they retract
my ladder of success is missing some rungs
