Update on the oil cooler #2509115
06/15/18 09:52 PM
06/15/18 09:52 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
The oil cooler is now installed. Bought a Derale 25 plate cooler and mounted it to the radiator. Primed the oil before i started it up and i could see i lost about 10psi oil pressure with the cooler in the system now and cold oil. Now at 70psi instead of the usual 80 on start up. Took it for a spin and oil temp never went above 200 on this 82* day. Coolant temp did go up a little higher thou at 200* in town cruising. With the cooler oil temp pressure not really an issue yet as it holds viscosity better now.
Re: Update on the oil cooler [Re: mopar dave] #2509120
06/15/18 10:00 PM
06/15/18 10:00 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Good to know and I still can't believe your builder recommended a fill in a street motor............. tsk Put the cooler somewhere else if possible as to not block the radiator......... thumbs
Re: Update on the oil cooler [Re: Thumperdart] #2509129
06/15/18 10:10 PM
06/15/18 10:10 PM
Mt Morris Michigan
Mt Morris Michigan
I built the motor. Best Machine is who suggested to fill the block instead of sleeving it. As for the cooler, Derale said it would not raise my coolant temp if it was mounted tight to radiator. 5* hotter is not bad i dont think. Most of the new stuff now runs 210-215*. Not gonna sweat it just yet. While the dist was out i recurved again. 1 stiffest and a blue spring. A large bushing from Don@FBO with only 6* advance. Set timing at 29* and all in at 34*. I know its not right, buts runs stronger and sounds way happier.
Re: Update on the oil cooler [Re: mopar dave] #2509341
06/16/18 02:52 PM
06/16/18 02:52 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Bad advice on any street car imo but what do I know......... thumbs
Re: Update on the oil cooler [Re: Thumperdart] #2509461
06/16/18 11:26 PM
06/16/18 11:26 PM
Mt Morris Michigan
Mt Morris Michigan
I agree, but there's so much hard block in there the cylinder is supported good IMO. 2 sleeves 1 and 8 would of been the best solution thou. I do have a better back up block now just in case. I'm very happy with this oil cooler thou. Can't believe how well the oil maintains its viscosity now. 30# of oil pressure at idle in drive now with 200* hot oil vs 15# with 250*+ hot oil.
Re: Update on the oil cooler [Re: mopar dave] #2509481
06/17/18 01:01 AM
06/17/18 01:01 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
you lost 10 psi thru the cooler? either your plumbing or the cooler is too restrictive. i used to make coolers years ago. had zero restriction when they were fitted.
Re: Update on the oil cooler [Re: mopar dave] #2509491
06/17/18 01:26 AM
06/17/18 01:26 AM
My old pump gas 400 block had four sleeves in it, two due to pitting, 1 and 7, and the other two, #4 and 6, due to block deck surface damage from a blown head gasket shruggy No block filler tsk
I have seen a really bad 400 block casting split a cylinder wall on the cam side on the dyno also puke I have learn to start with a good block casting or don't start until you can up
Re: Update on the oil cooler [Re: Cab_Burge] #2509494
06/17/18 01:35 AM
06/17/18 01:35 AM
Mt Morris Michigan
Mt Morris Michigan
yep. gonna run it til it breaks now.
Re: Update on the oil cooler [Re: mopar dave] #2509509
06/17/18 02:50 AM
06/17/18 02:50 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Running hotter is probably because you have less timing now.
Re: Update on the oil cooler [Re: CSK] #2509552
06/17/18 11:05 AM
06/17/18 11:05 AM
Mt Morris Michigan
Mt Morris Michigan
I thought too much timing would make them run hotter? Had a 69 Roadrunner i tuned up for a guy about 35yrs ago. The 383 in it always ran hot after i gave it a super tune which was a dist dissemble,cleaning and a good recurve with the lightest springs i could find installed, cranking timing up and a carb rebuild. Ran great,but always ran hot. Never figured it out and yrs later i start hearing about too much timing causing an over heat issue. Figured thats what it was.
Re: Update on the oil cooler [Re: rebel] #2509554
06/17/18 11:12 AM
06/17/18 11:12 AM
Mt Morris Michigan
Mt Morris Michigan
Its seems to me if i had a restriction i would have more oil pressure not less. I"v seen this before when others had added an oil cooler. Lost pressure.
Re: Update on the oil cooler [Re: mopar dave] #2509558
06/17/18 11:14 AM
06/17/18 11:14 AM
Mt Morris Michigan
Mt Morris Michigan
The point I'm making with the addition of the oil cooler is if you run quality oil and your losing excessive viscosity, than your oil may be running too hot. A good quality cooler will help as it did for me.
Re: Update on the oil cooler [Re: mopar dave] #2509586
06/17/18 12:54 PM
06/17/18 12:54 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
That's because the restriction of the cooler and it's assorted plumbing and adapter is upstream from your gauge port. That's why it shows less pressure.
Is your filter remote mounted too? All that extra plumbing causes restriction and most people undersize it to boot.
Kevin
Re: Update on the oil cooler [Re: mopar dave] #2509600
06/17/18 01:49 PM
06/17/18 01:49 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
thumbs
Re: Update on the oil cooler [Re: mopar dave] #2509619
06/17/18 02:44 PM
06/17/18 02:44 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
yep to much timing, did you limit his total timing ?
on my 512 with the vac adv on ported vac on the freeway it runs about 5 to 10 deg cooler hooked up. have had other cars do the same.
Re: Update on the oil cooler [Re: CSK] #2509628
06/17/18 03:05 PM
06/17/18 03:05 PM
I think to much or to little timing can cause extra heat to be ade in the motor, the sweet spot is the best scope
Test, test and test until you find it. Don't assume what yours is with YOUR timing light on YOUR motor is the same (identical to within 1/2 degree) as every one else's work
Re: Update on the oil cooler [Re: Cab_Burge] #2509667
06/17/18 05:01 PM
06/17/18 05:01 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
This ^^^^^^^
Re: Update on the oil cooler [Re: Twostick] #2509731
06/17/18 09:14 PM
06/17/18 09:14 PM
Mt Morris Michigan
Mt Morris Michigan
Ok. Didnt know that. Filter is in stock location. -8 lines as Derale suggested. Would that be a problem?
Re: Update on the oil cooler [Re: CSK] #2509733
06/17/18 09:19 PM
06/17/18 09:19 PM
Mt Morris Michigan
Mt Morris Michigan
No. Didnt figure it out quick enough. He kept running the crap out of it and blew the whole center out of 1 piston. #2 or #4. Cant remember.
Re: Update on the oil cooler [Re: Cab_Burge] #2509735
06/17/18 09:24 PM
06/17/18 09:24 PM
Mt Morris Michigan
Mt Morris Michigan
Well i did put one light spring in dist so i now have more timing cruising, but less total as now at 34* total. See what it wants at the track.
