Using Trick flow 270 heads #2507928
06/13/18 02:24 PM
06/13/18 02:24 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Anything special when installing the 270 trick flow heads ?
what head bolts ?
Special rocker arm set up ?
What else to look for too ?
Re: Using Trick flow 270 heads [Re: Wedgeman] #2507933
06/13/18 02:31 PM
06/13/18 02:31 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
Re: Using Trick flow 270 heads [Re: Wedgeman] #2507986
06/13/18 03:58 PM
06/13/18 03:58 PM
Morrow, OH
markz528 Online content
markz528  Online Content
Morrow, OH
I ended up buying a set of Harlan Sharp rockers designed for the Trick Flo head. Don't know how bad the geometry is with a stock rocker setup - I just bit the bullet and bought the correct ones. They are at the machine shop and will hopefully get installed next week.
There was a thread on rockers for Trick Flo heads - not sure if it was in the one linked above. That is a long thread.
Re: Using Trick flow 270 heads [Re: Wedgeman] #2508017
06/13/18 05:19 PM
06/13/18 05:19 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
rocker arm talk in that thread is around page 17, try going back a few pages as well...
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/2172923/17.html
Re: Using Trick flow 270 heads [Re: Wedgeman] #2508026
06/13/18 05:34 PM
06/13/18 05:34 PM
AndyF Offline
AndyF  Offline
I've written a bunch of magazine articles and posted a bunch of threads on here about the 270 heads.
Bottom line is they make a bunch of power right out of the box. My pump gas 470 makes 750 hp with the 270 heads.
Yes you need some longer head bolts, rocker shaft bolts are different, pushrods need to be longer, etc. Not really a big deal.
Re: Using Trick flow 270 heads [Re: AndyF] #2508077
06/13/18 06:57 PM
06/13/18 06:57 PM
birdtracker Offline
birdtracker  Offline
They make a head stud kit for them as well as head bolts. I bought the stud kit. I mocked up a set of Harland Sharp rocker arms that came off my Stage 6 heads and the roller was not even close to where it needs to be, even with lash caps, so I also bought the correct ones. Which ever version you buy plan on taking them apart and checking spring pressures, installed heights and especially coil bind. Piston valve reliefs will need to be checked to make sure you have clearance. Birdtracker
Re: Using Trick flow 270 heads [Re: Wedgeman] #2508091
06/13/18 07:24 PM
06/13/18 07:24 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Yeah,...just kinda noticed the HS rocker geometry is awfull....wich ones did you buy....I'm shopping right now......
Dan
Re: Using Trick flow 270 heads [Re: Wedgeman] #2508098
06/13/18 07:41 PM
06/13/18 07:41 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
I have just fitted mine .
ARP headbolt kit , I think same as Eddy Victor . ARP rocker shaft stud kit .
Summit lists all these , I bought from them .
Pushrods , mine were nearly 1" longer .
I reused my Crane gold 1.5 rockers , mock up at zero lash they were centre 1/3 of valve tip .
Valve spring pressures were dead on at height , just cleaned up up and honed guides .
Been running for a week , hope to get on chassis dyno next week .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Using Trick flow 270 heads [Re: Wedgeman] #2508099
06/13/18 07:41 PM
06/13/18 07:41 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
I have read almost nothing about either trick flow 240/270 that wasn’t for a magazine article. I don’t know why more people aren’t posting builds, and or results with them.
Re: Using Trick flow 270 heads [Re: viperblue72] #2508101
06/13/18 07:50 PM
06/13/18 07:50 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
back to the track for me on 30th June , 1/8 racing and maybe some 1/4 testing
hopefully my results will be good . hope to see 30rwhp gain any more is a bonus
Tex
New best MPH 130.32
Re: Using Trick flow 270 heads [Re: viperblue72] #2508102
06/13/18 07:51 PM
06/13/18 07:51 PM
birdtracker Offline
birdtracker  Offline
I just got my block back and am fitting stuff right now. My plan is to be running at Norwalk. Birdtracker
Re: Using Trick flow 270 heads [Re: Wedgeman] #2508106
06/13/18 07:58 PM
06/13/18 07:58 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Whitch rocker work best for those heads?
Re: Using Trick flow 270 heads [Re: Wedgeman] #2508115
06/13/18 08:33 PM
06/13/18 08:33 PM
birdtracker Offline
birdtracker  Offline
if you are using shaft oiling Harland Sharp. If you are using push rod oiling T&D. Birdtracker
Re: Using Trick flow 270 heads [Re: Wedgeman] #2508119
06/13/18 08:50 PM
06/13/18 08:50 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
The HS are too long on the nose.....they sit on the outer edge of the valve tip
Re: Using Trick flow 270 heads [Re: Wedgeman] #2508137
06/13/18 09:47 PM
06/13/18 09:47 PM
AndyF Offline
AndyF  Offline
Not if you buy the correct ones. This has all been covered before. I posted pictures, did a dyno test, wrote a magazine article, etc.
Re: Using Trick flow 270 heads [Re: AndyF] #2508197
06/13/18 11:28 PM
06/13/18 11:28 PM
birdtracker Offline
birdtracker  Offline
I just got mine and they fit perfectly.
https://www.summitracing.com/parts/csp-s70015ke
Birdtracker
Re: Using Trick flow 270 heads [Re: birdtracker] #2508222
06/14/18 01:00 AM
06/14/18 01:00 AM
Morrow, OH
Morrow, OH
Birdtracker
Those are the correct ones - same ones I have.
Re: Using Trick flow 270 heads [Re: tex013] #2508479
06/14/18 05:10 PM
06/14/18 05:10 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Tex
What cam you running with the golds?
I recall Andy saying the golds were on the money geometry-wise... but I'm not sure how long they will last with higher seat pressure... (running a small solid FT now...)
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Using Trick flow 270 heads [Re: OUTLAWD] #2508533
06/14/18 07:37 PM
06/14/18 07:37 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Tex
solid flat tappet . 272/272 - .600/.600 . Used these rockers for about 10 years now . From .509 hyd to this current cam . Current cam been in 18 months .
Springs now are 138 on seat 420 inch rate , had about sam on source heads
Tex
New best MPH 130.32
Re: Using Trick flow 270 heads [Re: tex013] #2508743
06/15/18 09:21 AM
06/15/18 09:21 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Tex
Thanks! I'm running the same rockers for a while now...~20 years. They still look like new when I pulled them off last year, so if it ain't broke I won't fix it. Looking to step up from my current ~.520 260/266 SFT when I swap heads
