Page 3 of 3 1 2 3
Re: High performance engines and pcv systems [Re: topside] #2508754
06/15/18 10:00 AM
06/15/18 10:00 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
I had one of those yrs back on my sb, but decided i didn't have that bad of a problem and just went back to open breathers. Mine pulled 3 or 5" of vac cant remember. It was just more wires and another switch. I understand that ford has one thats better than the GM pump. I'm going simple with this deal, open breather on one side and PCV valve on the other. Think i'll get some stuff ordered today.
Re: High performance engines and pcv systems [Re: Cab_Burge] #2508756
06/15/18 10:01 AM
06/15/18 10:01 AM
Mt Morris Michigan
Mt Morris Michigan
Yes, windage try in use.
Re: High performance engines and pcv systems [Re: madscientist] #2508759
06/15/18 10:10 AM
06/15/18 10:10 AM
Mt Morris Michigan
Mt Morris Michigan
Your right, that would be alot of oil to suck up in 9 or 10 seconds, but when the oil is hot and thin I'm sure alot of it ends up at the back of the pan on the launch and with some trapped up top could add up. I'm using the Edelbrock victor heads and they do seem to trap some oil on outer cover rail. Combine that with a Milodon high volume pump and that could be a problem. I will be sure to watch that gauge on first couple passes. Wont have time or money to get the 4.30 gear and spool out in exchange for a 3.73 and track loc diff, so 1/8 is what i will be running for this yr. Running out of oil in 1/8 should not be a problem thou.
Re: High performance engines and pcv systems [Re: mopar dave] #2508960
06/15/18 03:28 PM
06/15/18 03:28 PM
Dunnellon, FL
longram60 Offline
longram60  Offline
Dunnellon, FL
I had a PCV valve on my Belvedere. Had oil leaks after a pass down the quarter. I went with the electric vacuum pump, with a catch can before the pump. Eliminated my leaks!
1979 AMC Spirit, NHRA Q/SA
Re: High performance engines and pcv systems [Re: longram60] #2509112
06/15/18 09:45 PM
06/15/18 09:45 PM
Mt Morris Michigan
Mt Morris Michigan
I have some breathers with tubes on the way. Will see how they do.
Re: High performance engines and pcv systems [Re: mopar dave] #2510136
06/18/18 08:47 PM
06/18/18 08:47 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Originally Posted By mopar dave
Ok Cab. This is the pan i bought from you. Thought you said to use 1/2 qt over pan capacity to avoid sucking pan dry thru 1/4? Thought it was a 8qt, nope its a 7qt. So you say to use 6qts? May be main problem with oil pushing out with high rpm.
That looks like the same Moroso pan I use and I run just 7 qts in it. My dipstick reads full with 7 qts in the pan. I use a standard PCV valve in my pass valve cover and a breather on the drivers side. The hose on the breather nipple is open and draws the air into the crankcase as the hose just goes down under the brake booster and I loop it once and let it point to the firewall. I did that in case the breather would spit any oil when racing as I did not want it to spit oil on my valve cover but it does not get any oil even in that hose. My valve covers have a nice working baffle in them since no oil seems to ever spit out of the breather I use. It works great on the street as my eng pulls enough vacuum that the PCV system works fine driving on the street and I have no problems or oil leaks when I race. But I don't race alot as its only been about once a year lately. Ron
This is a better pic of the breather as its just a standard breather used on some production cars but it works fine for my setup. Ron
Re: High performance engines and pcv systems [Re: 383man] #2510169
06/18/18 09:45 PM
06/18/18 09:45 PM
Mt Morris Michigan
Mt Morris Michigan
Ok thanks Ron. I have some of those laying around. I ordered k&n open breather with black rubber top. Thought it looked better and maybe breath better as well. Oil level is lower with the install of the oil cooler as well. Doesnt blow nearly the oil now. Think i had a combo problem.
Re: High performance engines and pcv systems [Re: mopar dave] #2510323
06/19/18 10:56 AM
06/19/18 10:56 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
can you plumb a pcv into a 2 in. carb spacer or should it be lower, in the maifold.
Re: High performance engines and pcv systems [Re: bonefish] #2510333
06/19/18 11:46 AM
06/19/18 11:46 AM
Mt Morris Michigan
Mt Morris Michigan
As long as its below the carb its fine.
Re: High performance engines and pcv systems [Re: mopar dave] #2510369
06/19/18 01:36 PM
06/19/18 01:36 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Mine's in mt Dommy adapter in ft. and my pcv and breather are both in the ft. one on each each valve cover..........
Re: High performance engines and pcv systems [Re: mopar dave] #2510491
06/19/18 07:34 PM
06/19/18 07:34 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Overfilled oil: Accidentally did that on my '79 Chevy 4x4, thought for some reason it was a 6-quart capacity instead of 5-quart. It doesn't see RPM, mostly just runs into town on occasion & shoves a plow around in winter, but there was oil coming out of it everywhere, even a puddle of accumulated mist on top of the air cleaner & finned M/T valve covers I added for humor. It runs factory breather & PCV.
This in addition to the traditional SBC habit of weeping oil at every seam, mind you.
With 5 quarts, that extra rustproofing stopped.
It's a Targetmaster crate deal, not too many miles, previous owner did that some years back.
Re: High performance engines and pcv systems [Re: Spaceman Spiff] #2511218
06/21/18 08:53 AM
06/21/18 08:53 AM
Louisiana
BiomedTechGuy Offline
Louisiana
M/E Wagner...Great PCV valve. Got one for my 440 6 bbl that was blowing oil out the breather. The PCV valve I got when I changed from stock valve covers was just one that "fit" my new aluminum fabricated VCs. Just because it fits doesn't mean it's right.
M/E Wagner PCV valve is so good I'm getting a 2nd one for another car.
Re: High performance engines and pcv systems [Re: mopar dave] #2511756
06/22/18 02:52 PM
06/22/18 02:52 PM
AndyF Offline
AndyF  Offline
A remote breather tank works pretty good on a street/strip type of engine. I wouldn't use on a daily driver since a daily driver should have a PCV, but the breather tank solves a bunch of issues on a hot street/strip car.
I use a Moroso remote tank with two inputs and drain. They are tall and skinny so you can stick them next to the radiator or on the inner fender.
Page 3 of 3 1 2 3
