Torsion Bars install??? #2506606
06/10/18 02:40 PM
06/10/18 02:40 PM
Spokane Wa
slick526 Offline OP
slick526  Offline OP
Spokane Wa
This is probably a dumb question, does it matter when installing the torsion bars
that the R and L face forward or to the rear of the car?
Qwik Brick
Re: Torsion Bars install??? [Re: slick526] #2506622
06/10/18 03:04 PM
06/10/18 03:04 PM
Kirkland, Washington
Pacnorthcuda Offline
No, it doesn't matter, as the bar loads in the same rotational direction either way, but convention is that the numbers go to the rear.
Re: Torsion Bars install??? [Re: Pacnorthcuda] #2506629
06/10/18 03:22 PM
06/10/18 03:22 PM
Spokane Wa
slick526 Offline OP
slick526  Offline OP
Spokane Wa
For some reason, it seems like if you flip the bar around, it would be twisting
the opposite direction. ?????
Qwik Brick
Re: Torsion Bars install??? [Re: slick526] #2506680
06/10/18 05:06 PM
06/10/18 05:06 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Twist something and try it, swap ends and retest. report back what you find.
Re: Torsion Bars install??? [Re: slick526] #2506828
06/10/18 11:27 PM
06/10/18 11:27 PM
Eugene, Oregon
Secret Chimp Offline
Eugene, Oregon
Easiest to put the marks at the back with the flathead-looking slots aligned with the floor. That's how my old bars came out and my PST bars went in.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
