engine dies at idle when in D only when car is very hot.
#2504468
06/04/18 06:32 PM
06/04/18 06:32 PM
Posts: 106 Poland
willard
Poland
Sound weird but some time ago I replaced the ps pump, since then I drove the car few times. All fine. However three last runs finished with the engine stalling when I was pulling over and turing right to my garage. The steering wheel was turn full right but leass a couple degrees. Then I checked it once again in garage - engine idling I turn wheels and bam - stall. The assist is soft as it always was, no jerky wheel movements.
I have n o pump to replace and check so I ask your advice.
1970 challenger rt
Re: engine dies at idle when steering right
[Re: willard]
#2504492
06/04/18 08:01 PM
06/04/18 08:01 PM
CrazyD
Does the RPM drop before the stall, or does it cut out?
Does it stall if you remove the power steering belt?
[Re: willard]
#2504562
06/04/18 11:30 PM
06/04/18 11:30 PM
Posts: 4,457 Washington
madscientist
Washington
Don't turn right?
Sorry that's the best I've got. Wish I had better. Although is there a chance when turning right the ignition switch is getting tugged on by tight wires or something screwy at the bottom of the column?
That's all I got.
[Re: madscientist]
#2504576
06/04/18 11:46 PM
06/04/18 11:46 PM
Posts: 5,357 Rancho Cordova, California (Sa...
hemi71x
Ya, your probably loosing electrical contact somewhere in the electrical system. Check all connections everywhere. Firewall, coil, switch, anything corroded, or pinched.
RF-4C Phantom 69-370 Zweibrucken, Germany
[Re: willard]
#2504715
06/05/18 10:42 AM
06/05/18 10:42 AM
Guitar Jones
Its not electric related. Its like ps pump srops the engine. Car drives and turns fine when moving. Only when i turn wheels while car is stationary that happends. I guess relief valve may be stuck and pressure kills pump cause it cant escape ? Then take the belt off the power steering pump and try it as was suggested previously. Report back.
[Re: Guitar Jones]
#2504773
06/05/18 12:55 PM
06/05/18 12:55 PM
Posts: 43,553 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Pump cavitating and putting stress on the system? Does it do it full left also? Why did you change the pump? May need to adjust the steering box slightly. https://www.youtube.com/watch?v=m3KFaAbCr2Y
JB Rhinehart, Realist
A-Body's RULE!
[Re: willard]
#2505312
06/06/18 05:30 PM
06/06/18 05:30 PM
Posts: 25,808 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Its not electric related. Its like ps pump srops the engine. Weak tuneup or idle too low?
[Re: stumpy]
#2505693
06/07/18 07:06 PM
06/07/18 07:06 PM
Posts: 43,190 Bend,OR USA
Cab_Burge
If the pump locks up then that is your answer. Bad Pump. You change the pump and this problem started after y=that, correct? If so take that bad boy back and get a good one
[Re: willard]
#2506507
06/10/18 10:16 AM
06/10/18 10:16 AM
Posts: 106 Poland
willard
Poland
New facts - its not the p/s pump. Yesterday I drove 100+ miles in 100F heat and the problem emerged gradually as car was hotter. After first 30 miles of 60mph ride @3000 rpm when I stopped at red light the engine was in drive and died after 5 seconds, 20 miles later same thing but stalled right when I stopped. If I managed to put it in N before stop all was fine - no stalling. So definitely sth with temperature but:
- when stalled, it fired right away, no signs of boiling fuel, hard start. - fuel level correct - vacuum stedy in N and in D if engine is not hot (it it is warm nothing wrong happens, only after 15+ minutes of ride in hot conditions) - swapped chrome box for a blue napa unit - no change - When I pulled over and car rested for 20 minutes in sun, in 100F weather the problem was gone but got back in 10 minutes...
I thought maybe transmission got so hot it's starting to seize but could it survive all day ride then? Shifts fine, ATF is ok.
I think its not carb, not fuel, not ign box. May be coil overheated? Coil is blaster 2, dizzy MP magnetic, MP ballast (0.25), chrome box (with blue no change).
[Re: willard]
#2506514
06/10/18 10:42 AM
06/10/18 10:42 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Did you check for spark when it stalled?
I had a similar issue and it was my coil, new one fixed it. But it took awhile before the fault lasted long enough to find. Eventually, it stalled and I had no spark till it cooled off. But right now, it's guess work in your case.
[Re: willard]
#2506515
06/10/18 11:03 AM
06/10/18 11:03 AM
Posts: 905 SD
zrxkawboy
SD
Check the gap on your pickup coil.
It's Swifty! Swifty, you toad sucker!
