What type/brand sway bar bushings are you using? #2503500
06/02/18 10:06 AM
06/02/18 10:06 AM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Looking to install new front sway bar bushings in a 70 A-Body and I wanted to see what brand the community is using. I'm told the originals had a recessed/trough built into the rubber bushing to allow the grease to retain. I was told the polyurethane bushings may squeak over time. I wanted to reach out for professional advice before making a mistake.
Re: What type/brand sway bar bushings are you using? [Re: vinnyd76] #2503523
06/02/18 11:30 AM
06/02/18 11:30 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I use poly through out the suspensions in all my builds/customers for the last 2 or more decades, ZERO squeaks if installed and lubricated properly
Re: What type/brand sway bar bushings are you using? [Re: vinnyd76] #2503600
06/02/18 03:02 PM
06/02/18 03:02 PM
MA
steve70 Offline
steve70  Offline
MA
I looked but couldn't find anyone that made rubber replacements so I had to go with the poly version
1970 Challenger T/A 4 speed
