oil useage/poor gas milage #2503011
06/01/18 02:44 AM
06/01/18 02:44 AM
garnett kansas
rhad Offline OP
rhad  Offline OP
garnett kansas
buddy bought a 99 ram 1500,5.9 says it gulps oil and gas,nothing coming out the tailpipe or engine external leaks,my guess is the plenum leaking causing it to suck up oil,my question is will it running lean with the intake leak make the computer feed it more fuel to compensate for the lean condition,runs great,pulls great,6-7 mpg around town sounds wrong,will sucking that much oil thru the engine cause the convertor to plug causing poor fuel mileage?he says 100-150 miles to a qt of oil
my ladder of success is missing some rungs
Re: oil useage/poor gas milage [Re: rhad] #2503041
06/01/18 07:58 AM
06/01/18 07:58 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
I'd do that lower intake pan gasket, and put a new 195 thermo in there while you're at it. After that, put a cheapo scanner on it and see if all is well with fuel mixture etc at running temp.
Re: oil useage/poor gas milage [Re: buildanother] #2503228
06/01/18 04:05 PM
06/01/18 04:05 PM
dogdays Offline
dogdays  Offline
Agreed. Fix it soonest!
R.
Re: oil useage/poor gas milage [Re: rhad] #2503589
06/02/18 02:15 PM
06/02/18 02:15 PM
S.E. Minnesota
gtsdude Offline
gtsdude  Offline
S.E. Minnesota
Sounds just like my 99 Dakota with 5.2, it is getting fixed soon.
