Re: No dash lights on 67 GTX
[Re: GTX MATT]
#2505039
06/06/18 12:17 AM
06/06/18 12:17 AM
Posts: 732 USA
440mopar
USA
Do your oil pressure light, fuel, and temp gauges work? What about the turn signal indicators? Radio? The oil pressure and water temp gauges aren't hooked up due to aftermarket gauges having been installed at some point in the car's past. The alternator gauge moves when something electrical is turned on like the headlights. Turn signals, radio, heater blower all work. The fuel gauge I was told by the previous owner doesn't work but if that could be a byproduct of the instrument lights not working then it may work if I can solve the light problem.
[Re: Andrewh]
#2505072
06/06/18 02:41 AM
06/06/18 02:41 AM
RapidRobert
then I would start with power to the light harness, I might even back feed through one of the sockets to test the bulbs. that's what I would do, jump fire to the specific female brass cavity in the black bakelite headlight switch "bulkhead" & work downstream for the open.
[Re: 440mopar]
#2514399
06/28/18 01:03 PM
06/28/18 01:03 PM
Posts: 19,355 north of coder
moparx
if all components check good, and everything is properly grounded, the only thing it can be is the circuit is NOT getting power. this means you need to check the wiring closely. even if nothing apparent jumps out [like a blown fuse, or broken wire], you need to confirm if power [12v] is reaching the switch, then leaving the switch to the component[s]. after that, you need to confirm the component[s] is[are] receiving 12v. you may need to run a jumper wire or two, to confirm this. these cars have a very basic system, but electrical issues can be VERY frustrating to solve at times. i REALLY enjoy fixing hack "fixes". [ ]
