No, you're not.
The post 1976 318s DID use the 360 style 645 rods and a regular 318 cast crank.
They were pressed pin, same as all 360s and all the 645 rods used on 318s, which may have started as early as 1973.
I have never heard of a cast 318 crank having problems with strength.
The 645 rods weigh 758 grams apiece. You can save around 150 grams EACH by changing to a light aftermarket rod. Add a piston like the KB 167 and save a total of 240 or more grams PER PISTON. That's more than 1/2 lb per piston.
Even the early "skinny" 318 rods are 726 grams.
A piston and rod from a 318 weigh like a bigblock set from other than Chrysler engines.
R.
