Longer front wheel studs, where to find.
#2500744
05/26/18 06:57 PM
05/26/18 06:57 PM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
I need wheel studs for factory unicast disk brake rotors that are about 1/4 inch longer than stock. I've never been really comfortable with the little bit of thread sticking out through my aluminum rims and since I have everything apart it seems like a good time to swap them out.
Is there a source/part number/application that will work for me that someone can post?
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
Re: Longer front wheel studs, where to find.
[Re: TrackPack]
#2500817
05/26/18 10:15 PM
05/26/18 10:15 PM
Posts: 20,189 Park Forest, IL
slantzilla
Park Forest, IL
Check out Dorman products. I used to have a part number for a 2" stud with the correct sized knurl, but can't find it. They have many lengths available Wasn't there a stud for a Lincoln that was longer?
[Re: slantzilla]
#2500825
05/26/18 10:36 PM
05/26/18 10:36 PM
Posts: 103 Minnesota
TrackPack
Minnesota
Check out Dorman products. I used to have a part number for a 2" stud with the correct sized knurl, but can't find it. They have many lengths available Wasn't there a stud for a Lincoln that was longer? Huge assortment at Jegs.
[Re: Michael Ecks]
#2501046
05/27/18 05:13 PM
05/27/18 05:13 PM
Michael Ecks
Columbus, GA
Thanks for looking that up trackpack! ORielly had them in stock local and they are already on the car. Here's a couple pics for reference. Long on is the dorman part trackpack showed, middle is out of the large rotors from Dr. Diff's kit, and the old one with the massive head is from I believe a stock A body rotor I did the disc swap with years ago on my challenger.
Once I cut the quick start nub off end they were the same length of thread as the screw in studs on my Dr. Diff axles. Probably had plenty of engagement already but since you can't see with closed end nuts and my aluminum rims are way thicker than stoxk steels, it was worth it for peace of mind.
