amp gauge: a right and wrong way
#2500419
05/25/18 07:10 PM
05/25/18 07:10 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Hey guys...
This may sound like a VERY silly question... But, when it comes to our era amp gauges, this case a 67 Plymouth, is there a proper "left" and "right" post when attaching the red and black wires? I would think the gauge just senses the current regardless of the way it is traveling through it... I could be wrong...
I went to hook up the battery after reinstalling the instrument cluster and dang, the fusible link went up and smoke. Smoke even came out of the ground point on the radiator core support where the negative battery cable body ground attaches... Never saw that one before... I quickly removed the positive cable from the battery and checked the wiring under the dash at the bulkhead connector and outside on the firewall. The only wire that seems to have been affected is the fusible link... Whew....
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
Re: amp gauge: a right and wrong way
[Re: hemi68charger]
#2500431
05/25/18 07:51 PM
05/25/18 07:51 PM
Posts: 1,169 clarks summit pa
73cuda340
clarks summit pa
Not sure about a 67, but I just did a dash swap on my cuda and underneath the studs, it was stamped on the back showing which wire went to which stud. By reversing the wiring it may affect the gauge reading as to whether it is drawing current or charging. Not sure though.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
[Re: hemi68charger]
#2500438
05/25/18 08:15 PM
05/25/18 08:15 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Hey guys...
I went to hook up the battery after reinstalling the instrument cluster and dang, the fusible link went up and smoke. Smoke even came out of the ground point on the radiator core support where the negative battery cable body ground attaches... Never saw that one before... I quickly removed the positive cable from the battery and checked the wiring under the dash at the bulkhead connector and outside on the firewall. The only wire that seems to have been affected is the fusible link... Whew.... Sounds like you screwed the pooch, while the gauge is designed to work in series, there is correct manner in which the current flows thru the gauge, should be marked with "red", or "S" on the primary terminal of the gauge to receive the red wire, black/dark blue on the other terminal FYI, replace those "paper" mounting insulators on the posts with some nylon washers...make sure your isolating the studs properly in the dash cluster
[Re: stumpy]
#2500439
05/25/18 08:17 PM
05/25/18 08:17 PM
hemi68charger
Houston, Tx
Yeap. That is what I was afraid of. Wondering if the starter relay could cause it. Otherwise, I am going to pull the cluster out again and see if the amp gauge shifted some how on the frame and touching it.
[Re: DAYCLONA]
#2500452
05/25/18 08:52 PM
05/25/18 08:52 PM
hemi68charger
Houston, Tx
Hey guys...
I went to hook up the battery after reinstalling the instrument cluster and dang, the fusible link went up and smoke. Smoke even came out of the ground point on the radiator core support where the negative battery cable body ground attaches... Never saw that one before... I quickly removed the positive cable from the battery and checked the wiring under the dash at the bulkhead connector and outside on the firewall. The only wire that seems to have been affected is the fusible link... Whew.... Sounds like you screwed the pooch, while the gauge is designed to work in series, there is correct manner in which the current flows thru the gauge, should be marked with "red", or "S" on the primary terminal of the gauge to receive the red wire, black/dark blue on the other terminal FYI, replace those "paper" mounting insulators on the posts with some nylon washers...make sure your isolating the studs properly in the dash cluster Hey Mike. On the back of this GTX's circuit board there isn't any markings, either from not having them to begin with or age and many hands touching it over time. Done plenty of Rallye clusters and they do have a RED marking on the housing. Not so on this GTX. Like your idea on the nylon washers.
[Re: Magnum]
#2500472
05/25/18 09:55 PM
05/25/18 09:55 PM
hemi68charger
Houston, Tx
The right way is not have the entire electrical circuit passing through a gauge. Understood... But the owner can't get the conversion system.... I have done it on pretty much all my cars over the last decade...
[Re: hemi68charger]
#2500476
05/25/18 10:16 PM
05/25/18 10:16 PM
hemi68charger
Houston, Tx
Well Hell..... There is a "RED" stamped in the printed circuit board.. I think I had them backwards..... Live and learn...
[Re: Magnum]
#2500482
05/25/18 10:37 PM
05/25/18 10:37 PM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
The right way is not have the entire electrical circuit passing through a gauge. It doesn't. Only the battery circuit.
[Re: hemi68charger]
#2500483
05/25/18 10:42 PM
05/25/18 10:42 PM
Mattax
Phila. Pa.
Well Hell..... There is a "RED" stamped in the printed circuit board.. I think I had them backwards..... Live and learn... But if they were backward, all it would do is show current going in the wrong direction. In other words it would show charging the battery when it was discharging. Definately a major short downstream of the link. Fusible Link in Charging Systems with Ammeters The advantage of the original layout is the one link protects everything from the battery grounding. This means the alternaotr output wire can be run to the distribution points without additional fusible links - which of course add resistance under high draw situations.
[Re: Mattax]
#2500496
05/25/18 11:03 PM
05/25/18 11:03 PM
RapidRobert
What Mattax said, you have a dead short somewhere (likely at the ammeter terminals to ground) & if you have the red/black wires/terminals on the wrong ammeter posts it will just read backwards (but no harm/no foul) on that issue anyhow.
[Re: RapidRobert]
#2500524
05/26/18 12:31 AM
05/26/18 12:31 AM
hemi68charger
Houston, Tx
I found an extra original fusible link ( i'm glad I keep my old harnesses )... I replaced it, and with the instrument cluster removed, I joined the black and red amp gauge leads... Placed the positive back on the battery and no harm... Used my screw driver to test the starter relay and it worked just fine.... So, something is going on with the cluster.. I have a good insulator between the gauge and housing, so I'm not sure.. The gauge doesn't appear damaged.. It is a pretty simple design mechanically...
[Re: hemi68charger]
#2500535
05/26/18 01:49 AM
05/26/18 01:49 AM
RapidRobert
I'd dig into the gauge when you can & find where it is dead shorted to the (ammeter) case.
[Re: hemi68charger]
#2500612
05/26/18 10:52 AM
05/26/18 10:52 AM
Mattax
Phila. Pa.
From what has been described, if there was a short in the ammeter, there should be evidence. It should show signs of heat and smell of burnt metal and plastic. Shouldn't have to open it to determine if its OK.
I say this because the fusible link went fast, and it was enough current that even the body ground couldn't handle it. Of course if the body ground wasn't a great connection to begin with, then that does't means so much.
Some place the hot wire had pretty good contact with the body. That is, assuming the engine block connection direct to the battery negative was good.
[Re: Mattax]
#2500641
05/26/18 12:00 PM
05/26/18 12:00 PM
RapidRobert
I would highly suggest doing Nachos bulkhead parallel bypass. You run in addition to the OE 2 main in/out wires/4 brass terminals, with 2 new wires seperately around the bulkhead/thru a new hole/grommet in the firewall, like exits that curve around a border crossing/keeping the OE bulkhead 4 brass terminal connection OR just drill out the 2 bulkhead cavities for those 2 wires & run/solder 2 new wires straight thru with no brass terminals (leave 6" of the 2 wires behind the rear bulkhead half so if you have to pull em apart in the future you can do so).
