Re: Pin gauges
[Re: BradH]
#2500479
05/25/18 10:24 PM
05/25/18 10:24 PM
Posts: 5,992 Anoka County, MN
Leigh
Anoka County, MN
Drill bits or pin gauges, check every one you use with a micrometer to see what size it really is, not what it's supposed to be.
I also suspect that some import pieces are the closest metric size, rather than the correct inch size, based on some of the variations in measurements I've found. This.
Re: Pin gauges
[Re: Leigh]
#2500633
05/26/18 11:39 AM
05/26/18 11:39 AM
Posts: 19,591 north of coder
moparx
I also suspect that some import pieces are the closest metric size, rather than the correct inch size, based on some of the variations in measurements I've found. This. but remember one thing. a "xxx" size drill or pin will NOT fit in the same identical size "xxx" hole. that requires a press fit.the pin or drill MUST be a couple of tenths undersize to fit the hole. just machining 101. also, watch the edge of the pins when getting close to your hole size determination, as it is easy to get the sharp radius of the pin end to cause a gouge if started crooked in the hole being measured. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
Re: Pin gauges
[Re: moparx]
#2500792
05/26/18 08:51 PM
05/26/18 08:51 PM
RapidRobert
^^^ good stuff! (I needed that info).
Re: Pin gauges
[Re: DusterKid]
#2500807
05/26/18 09:52 PM
05/26/18 09:52 PM
Posts: 11,692 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I have a pin drill set, 61-80, (.0135-.039), and number bits along with fractionals. I've used these for pump squirters, air bleeds, jets, oil restrictors, etc on all kinds of stuff. Personally have never needed anything more precise. Don't forget the pin vice.
Re: Pin gauges
[Re: moparx]
#2500841
05/26/18 11:18 PM
05/26/18 11:18 PM
dartman366
Mt. Vernon, Ohio
I also suspect that some import pieces are the closest metric size, rather than the correct inch size, based on some of the variations in measurements I've found. This. but remember one thing. a "xxx" size drill or pin will NOT fit in the same identical size "xxx" hole. that requires a press fit.the pin or drill MUST be a couple of tenths undersize to fit the hole. just machining 101. also, watch the edge of the pins when getting close to your hole size determination, as it is easy to get the sharp radius of the pin end to cause a gouge if started crooked in the hole being measured. 99% of the time a drill bit will cut a few thousands over the drill size, if you want a precise fit then drill under and then ream the hole for the required size and even then a ream will cut over/under depending on the type of coolant/lubrication used,but usually with-in tenths of being on size.
Re: Pin gauges
[Re: hemi-itis]
#2500861
05/27/18 12:04 AM
05/27/18 12:04 AM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I bought a set years ago to use for checking valve guide clearances and for a few other projects
Re: Pin gauges
[Re: 383man]
#2500896
05/27/18 03:31 AM
05/27/18 03:31 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I bought my 2 sets off of ebay.. goes from .011 up to .250.. and yes I mic them every time I use 1 ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
