4 Speed clutch pedal torque shaft finish #2500038
05/24/18 04:17 PM
05/24/18 04:17 PM
Armada MICH.
DUSTER_340 Offline OP
Armada MICH.
I am looking for the correct finish on an A body four speed clutch pedal torque shaft. I know the reproductions are nicely plated silver , but I don't believe that to be correct. Does any one have any pictures of an untouched original ?
Re: 4 Speed clutch pedal torque shaft finish [Re: DUSTER_340] #2500196
05/25/18 06:21 AM
05/25/18 06:21 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Dip painted black.
Re: 4 Speed clutch pedal torque shaft finish [Re: kentj340] #2500495
05/25/18 11:02 PM
05/25/18 11:02 PM
Armada MICH.
Armada MICH.
Thank You up
Re: 4 Speed clutch pedal torque shaft finish [Re: DUSTER_340] #2500540
05/26/18 02:25 AM
05/26/18 02:25 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
More than 3 dozen brackets and such on my 69 Barracuda were dip painted black with visible runs. If you search for runs on such items, you may find them, typically downhill from an obvious place to hang the piece on a wire hook to dry.
Even the seat frame assemblies were dip painted black.
Hollow items not suitable for dipping, such as the K frame and rear axle housing, were spray painted black. Mostly everything else made in house by Chrysler that was black was dip painted.
For more information on how to dip paint found in an Amazon book (you can search inside), see:
https://board.moparts.org/ubbthreads/ubbt...ket-finish.html
