4 speed wont go into forward gears #2499840
05/24/18 04:10 AM
05/24/18 04:10 AM
spokane/pullman Wa
ryanf Offline OP
ryanf  Offline OP
spokane/pullman Wa
Hello, i had picked up a good working 4 speed 6ish years ago and finally have everything set up and the engine is running, however The transmission won’t shift into any forward gears, it goes into reverse easy, I removed the shifter linkage put the pin in to line it up checked it against the transmission arms and they are all lined up correctly. The arms on the trans separate of the shifter can’t be moved on their own except the reverse shift arm. Anyone have an idea on what could be the issue?
Ryan
Re: 4 speed wont go into forward gears [Re: ryanf] #2499848
05/24/18 05:23 AM
05/24/18 05:23 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
If it's the later year style with those interlock levers inside, you may want to pull cover to see that they are properly aligned.
Re: 4 speed wont go into forward gears [Re: ryanf] #2499864
05/24/18 09:03 AM
05/24/18 09:03 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
Reverse lever installed upside down?
Re: 4 speed wont go into forward gears [Re: PhillyRag] #2499937
05/24/18 12:22 PM
05/24/18 12:22 PM
spokane/pullman Wa
ryanf Offline OP
ryanf  Offline OP
spokane/pullman Wa
By later style do you mean the overdrive transmission? As this is not an over drive. If not do you have a picture of how they should look?
And thanks toomany62's i've verified the rods are all correct.
Ryan
Re: 4 speed wont go into forward gears [Re: ryanf] #2500113
05/24/18 08:16 PM
05/24/18 08:16 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Time to pull the side cover...
Re: 4 speed wont go into forward gears [Re: Jim_Lusk] #2500124
05/24/18 09:44 PM
05/24/18 09:44 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree beer
Re: 4 speed wont go into forward gears [Re: ryanf] #2500143
05/24/18 11:24 PM
05/24/18 11:24 PM
NP made two different styles of the side covers that went onto the NP833 trannys put in Mopar 4 speed cars, the early ones where used from 1964 to 1971 or so. The early ones used the rooster comb type selectors, the later ones used the scissors type side covers like GM used with the better steel shifting forks up
On your deal I would disconnect all the shifter rods from the shifting arms and make sure the tranny is in neutral and then see if you cam manually shifted the 1st and second shifter arms on the side case, same thing on the 3rd and 4th arm scope
if you can't move them then the tranny has issues inside shruggy twocents scope
Re: 4 speed wont go into forward gears [Re: Cab_Burge] #2500171
05/25/18 01:02 AM
05/25/18 01:02 AM
spokane/pullman Wa
ryanf Offline OP
ryanf  Offline OP
spokane/pullman Wa
ok thanks i will try and take a look. Does anyone know someone around the Spokane WA - Coeur D'Alene area that they would recommend to take a look? The car is on a lift in a garage and i am out of my knowledge here and would prefer not to screw anything up.
Ryan
Re: 4 speed wont go into forward gears [Re: ryanf] #2500181
05/25/18 02:07 AM
05/25/18 02:07 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Can't load a pic, but later year shift interlock cover has a Rib on side cover between the 2 shift link studs.
Re: 4 speed wont go into forward gears [Re: PhillyRag] #2500215
05/25/18 09:34 AM
05/25/18 09:34 AM
N.Y.
sixpacksteve Offline
N.Y.
pull the side cover!
Hell Hath No Fury Like Mine
