Do new torsion bars "settle" after set up? #2498955
05/22/18 09:51 AM
05/22/18 09:51 AM
Columbus, GA
Michael Ecks Offline OP
Columbus, GA
Installed a set of .960 MP bars in my challenger to replace the original 318 bars. Just wondering if I should expect any settleing (like leaf springs) after I do the initial ride height setup or if they will pretty much stay where the are now.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: Do new torsion bars "settle" after set up? [Re: Michael Ecks] #2498963
05/22/18 10:12 AM
05/22/18 10:12 AM
BDW Offline
BDW  Offline
I put in same bars and they never settled, still the same 5 yrs later.
Re: Do new torsion bars "settle" after set up? [Re: Michael Ecks] #2499181
05/22/18 07:34 PM
05/22/18 07:34 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
I've never experienced settling.
Re: Do new torsion bars "settle" after set up? [Re: Michael Ecks] #2499198
05/22/18 08:18 PM
05/22/18 08:18 PM
AndyF Offline
AndyF  Offline
The torsion bars don't settle but the front end will depending on how you bolted it together. The correct process is to put the front bushings together snug on the lift and then torque them down at ride height. If you torque stuff together while the car is on the lift (common mistake) then the car will slowly settle over time as the weight of the car twists the bushings. If you put the car together correctly then it should hold the ride height after you drop it on the ground.
Re: Do new torsion bars "settle" after set up? [Re: Michael Ecks] #2499432
05/23/18 12:23 PM
05/23/18 12:23 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Only if your bigger smile weighs more while driving. up grin
Re: Do new torsion bars "settle" after set up? [Re: Michael Ecks] #2499753
05/23/18 11:47 PM
05/23/18 11:47 PM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
I say yes they do, put a set in my Duster years ago and had to readjust them a few times in the first few days.
But then they were fine after that
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
Re: Do new torsion bars "settle" after set up? [Re: moparts] #2499764
05/24/18 12:03 AM
05/24/18 12:03 AM
I cant say one way or another but I'm inclined to think (most) everything changes/settles downward. A person could measure between the bolt on mini rubber bumper/LCA for future reference (not note taking has been my downfall!).
