A body 8 3/4 axle shaft won’t come out
#2498707
05/21/18 06:16 PM
05/21/18 06:16 PM
Posts: 59 British Columbia, Canada
340Forrest
Hey everyone I got a 69’ Dodge Dart parts car that has a 3.91 489 sure grip that I want out of it. Pulled the drivers side axle no problem at all, passenger side will not come out, been at it for hours, resorted to beating on it with a hammer, 5 ft pry bar etc, all 5 nuts are off, it looks like the bearing is packed with dirt, sand from the sandblaster and rust, any recommendation on how to get it out? I just want this carrier!!! Thanks in advance, I’ve never had this issue with any of the other 8 3/4s I’ve done.
Re: A body 8 3/4 axle shaft won’t come out
[Re: 340Forrest]
#2498719
05/21/18 06:29 PM
05/21/18 06:29 PM
RapidRobert
put the drum on backwards with the lug nuts on backwards just enough so the stud(s) threads are flush with the end(s) of the nuts & use it as a slide hammer.
[Re: 340Forrest]
#2498721
05/21/18 06:33 PM
05/21/18 06:33 PM
Posts: 8,681 Buford, GA
I_bleed_MOPAR
Buford, GA
Maybe borrow a slide hammer from a friend or do the loaner tool from a parts house. Being a retired tech I have my own. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: 340Forrest]
#2498725
05/21/18 06:41 PM
05/21/18 06:41 PM
Posts: 21,844 Kirkland, Washington
Pacnorthcuda
Since the drivers side axle is out, shove a broomstick in until it bottoms out against the pass axle end and give it a whack.
Edit.....forgot about the thrust button, this won't work
[Re: 340Forrest]
#2498731
05/21/18 07:00 PM
05/21/18 07:00 PM
Posts: 96,666 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
tie a cable to the reversed brake drum, or wrap with cable around drum
tie cable to 4x4
drive away FAST with a BIG jerk. (that is a 'tug', not an idiot in the 4x4 with you lol )
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: amxautox]
#2498783
05/21/18 09:22 PM
05/21/18 09:22 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
^ I could imagine a car falling off axle stands here.
Has this axle seen slicks? Spline could be twisted.
[Re: Magnum]
#2498790
05/21/18 09:37 PM
05/21/18 09:37 PM
amxautox
OH YA!
Tom
author unknown
[Re: 340Forrest]
#2498827
05/21/18 10:59 PM
05/21/18 10:59 PM
RapidRobert
I just want this carrier. & when we get it out I wanna buy the housing from you.
[Re: MoparMike1974]
#2499752
05/23/18 11:42 PM
05/23/18 11:42 PM
RapidRobert
If that is a real 8 3/4 A body housing you should find a good home for it. I agree, I will provide a very good home for it, lots of love & nurturing .
