throttle linkage set-up new QFT carb #2497245
05/17/18 04:16 PM
05/17/18 04:16 PM
Penna
70satelliteguy Offline OP
Penna
Info in package has four different rods and hole combinations to choose from but no recommendations.
(1) 1 to 1 ,(2)moderate progressive 25% primary throttle opening,(3)medium progressive 40% primary throttle opening and(4) full progressive 50% primary throttle opening.
Looking for best set up for transbrake and 2 step.
Tech line was no help at all. took him ten minutes to look up the info while I was on hold and he simply read back to me what I have typed above!!! Not even sure he understood what a transbrake is!
Mike
Re: throttle linkage set-up new QFT carb [Re: 70satelliteguy] #2497278
05/17/18 05:48 PM
05/17/18 05:48 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
Why would trans brake make a difference on throttle ratio?
JAKES AUTOMOTIVE
Re: throttle linkage set-up new QFT carb [Re: JAKE68] #2497298
05/17/18 06:21 PM
05/17/18 06:21 PM
Penna
Penna
The throttle linkage set-up controls the secondary pumpshot using different rods and holes in the linkage to shoot into open throttle blades,25% opening,40% opening or 50% opening. When using a transbrake(stomping it to the floor on 2 step) having it improperly set can cause stalling,sputtering etc.
I'm looking for the best adjustment for a smooth transition.
Mike
Re: throttle linkage set-up new QFT carb [Re: 70satelliteguy] #2497317
05/17/18 07:34 PM
05/17/18 07:34 PM
I would put it in the 50 % hole to start with and go from there up scope
That way you can drive it in the pits and do a controlled burn out with the same setting work
Re: throttle linkage set-up new QFT carb [Re: 70satelliteguy] #2497342
05/17/18 08:19 PM
05/17/18 08:19 PM
AndyF Offline
AndyF  Offline
I don't know the answer to your question but if it was me I'd go to the track and test #1 and #4. If you can't tell any difference then it doesn't matter. If there is a big difference then either use the setting that works the best or try #2 and #3.
You might need to play with the pump cam and/or the shooter size also to get the car to leave hard off the brake. Setting up a carb to leave off the brake is different than setting up a carb for a daily driver so you might have to forget what you know about carbs and start over.
