How much tranny fluid...... 904 with deep pan
#2496581
05/15/18 07:41 PM
05/15/18 07:41 PM
Posts: 11,724 Portage,michigan
B3422W5
Portage,michigan
Will add 1 to convertor, then how much more Thanks
Re: How much tranny fluid...... 904 with deep pan
[Re: stumpy]
#2496612
05/15/18 08:19 PM
05/15/18 08:19 PM
B3422W5
Portage,michigan
At least 6 then check it. Fill to the full mark on the dipstick. Deep pan doesn't change the full level just the amount of fluid needed to get there. Did you install the filter spacer? Its a Cope built tranny, has spacer
[Re: B3422W5]
#2496951
05/16/18 09:05 PM
05/16/18 09:05 PM
Posts: 20,201 Park Forest, IL
slantzilla
Park Forest, IL
My 904 with a deep pan and 8" converter took 9 total.
[Re: slantzilla]
#2497388
05/17/18 11:17 PM
05/17/18 11:17 PM
B3422W5
Portage,michigan
My 904 with a deep pan and 8" converter took 9 total. Thanks bud. It ended up taking 9. Now cant wait to try it. Hopefully Fri night at 131
