Fast EZ EFi 1.0 #2496914
05/16/18 06:59 PM
05/16/18 06:59 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
Hi everyone, need a little help.
I have somehow lost all my info on my PCM in the car and it runs like Poop.
Its in the AFR adjustments from what I can tell.
I am setting up the afr as follows for my 415 sb.
Idle AF 12.0
Cruise AF 13.5
WOT AF 14.0
Everything has gone south so I need a little help.
Thank you all
Thank you
Kiddart
Re: Fast EZ EFi 1.0 [Re: Kiddart] #2496919
05/16/18 07:09 PM
05/16/18 07:09 PM
I would try 14.3 or leaner on the idle AFR, light part throttle cruise at 14.5 to 15.5 AFR and shoot for 12.5 to 13.3 AFR at WOT and tune from there twocents scope
Re: Fast EZ EFi 1.0 [Re: Kiddart] #2496941
05/16/18 08:19 PM
05/16/18 08:19 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
I believe mine did the same. Lost its "tune" over the winter.
Didn't want to start the other day. I took it for a ride Monday and it was popping and bucking
Re: Fast EZ EFi 1.0 [Re: Kiddart] #2497862
05/19/18 01:20 PM
05/19/18 01:20 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
what do you have a baseline AFR in the pcm.
Thank you
Kiddart
