Re: 440 running lean on cyl 7&8 with 6 bbl?
[Re: 72demon416]
#2495750
05/14/18 12:07 AM
05/14/18 12:07 AM
Posts: 43,227 Bend,OR USA
Cab_Burge
Have you adjusted the idle fuel mixtures on both outboard carbs. yet? If not do that next, the idle mixture screws may have lead covers on them, there in the bases under the fuel bowls I set my stock outboard carbs. up from 1/4 to 1/2 turn out from gently closed all the way BTW, I'm assuming you have new Holley replacement carbs. and not some other brand, do you? Let us know what you find, that will help others on here later
[Re: 72demon416]
#2495774
05/14/18 12:56 AM
05/14/18 12:56 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Yes I have the outboards done, the front was about 1.25 turns out on the base screws and the rears are closed right off. This was done covering the outer idle bleeds and adjusting until the idle speed did not vary. I’m a little surprised the fronts wanted that much while the rears wanted nothing. These are the new replacement Holley carbs where the idle screws are in the base. Not real impressed by the quality control on them.... I certainly see why guys buy the metering blocks to upgrade the outboards carbs adjustability. Sounds like you got quite a mess going on, I know you won't like it, but I'd start by pulling the intake and looking for a cracked runner IMHO, new Edelbrock 6 pack manifolds like to crack around cylinders 6, 7, and 8... but a crack could be anywhere, plus the Edelbrock BB sixpack manifolds are notorious for gasket sealing issues, what gaskets are you running?, plus a dry fit of the manifold is in order to check if it's mating with the heads/intake ports squarely
[Re: 72demon416]
#2495800
05/14/18 02:23 AM
05/14/18 02:23 AM
Posts: 1,908 Nebraska
4406bbl
Nebraska
All 6 bbls feed idle fuel, and idle fuel flows at 2600 rpm, actually it flows to some degree at all rpm. I would guess with the rear carb idle screws being closed that is a big part of your lean problem. I would try all the outboards at about a 1/2 turn and see if it helps the lean problem. I don't think you want no changes when you cover outboard idle bleeds, if you cover them and it should get rich and lose a few rpm if its right in my opinion. It is possible the rear metering plate idle gas feeds are the wrong size, or blocked, could be blocked or restricted in center metering plate also. You need to get all 6bbls helping with the idle, and it seems best with outboards at 1/4-1/2 turn, center at 1 to 1-1/2, actual mixture, idle air to fuel ratio is done with idle gas feeds and bleeds, more the gas feed than bleeds as drilling those is a good way to ruin a carb. Some of these newer 6bbl carbs are a nightmare.
[Re: 72demon416]
#2495896
05/14/18 11:47 AM
05/14/18 11:47 AM
4406bbl
Nebraska
If the rear idle circuits are contributing at that rpm then that would definitely make sense then! I’ll fatten up the front carb a bit (because I can get to the mixture screws) and then move it to the the rear and see what happens. Thanks! Yes they contribute at idle and have a transition slot for when the outboards first open. Try to put all 4 outboard idle screws out the same amount. I would start at 3/8 or 1/2 and see where the center ends up.... if its less than one turn out on the center the rears need to be turned in more, more than 2 turns turn the outboards out more. A general rule is 1/8 turn on all 4 outboards =1/2 turn on center, not always a perfect ratio or all carbs but to help get you in the ballpark since its so fun adjusting that rear.
[Re: 4406bbl]
#2495976
05/14/18 02:21 PM
05/14/18 02:21 PM
Posts: 18,157 Mass
DAYCLONA
Mass
since its so fun adjusting that rear. When the OP gets around to checking off just the basics, before attempting a tune on the carbs, a member here sells special base plate screws and the required tool to make adjustments, esp on the rear carb easier while running, simple swap... contact Bud Weaver at Sixpack Solutions (Moparts member 69sixpackbee) Mike
[Re: 72demon416]
#2495986
05/14/18 02:43 PM
05/14/18 02:43 PM
Posts: 4,570 Motor City
6PKRTSE
Motor City
I always adjust the center one first then get the front carb to wear I like it & then move it to the rear & then adjust the front one last again, makes it easier that way. I would also try that to see if your lean condition will now move towards the front of the engine along with the carb. The you know it's the carbs & not an intake issue.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 72demon416]
#2496015
05/14/18 03:24 PM
05/14/18 03:24 PM
Posts: 959 Chicago
PurpleBeeper
Chicago
I don't mean to add fuel to the fire, but hopefully this will help. 1. You will get there, be patient. 2. There is a good chance the intake is not sealed, underneath, in the back (cyl #7 & #8) 3. How do you know it's running lean on #7/#8? Plug reading?
When I was fighting my 6-pack issues, neither of my center carb idle screws did anything. I had the transfer slots uncovered, go the center carb more closed & then only ONE of my center carb idle screws did anything. I took the carb apart, cleaned everything & found a "glob of oil smutz" inside the metering body...cleaned it & both idle screws now work. Hope that little story help... I know you have new carbs, but...
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: 72demon416]
#2496069
05/14/18 05:59 PM
05/14/18 05:59 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
You DID install a plug or vacuum fitting in the back of the manifold and hook up the vacuum lines? Yes, I've seen it left out and overlooked.
Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: 3hundred]
#2496098
05/14/18 07:02 PM
05/14/18 07:02 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Robert It's funny, but not, at the same time, I've seen this as well on a few intake swaps/upgrades when asked to "look" at someones install/tune that's not running/running like crap.... I've also seen where some guys left the PCV hose that Holley ships the sixpack center carb with still hooked up to the bowl vent tube sucking the gas right out of the bowl and they wondered why it ran like crap or even stayed running... the OP should post some pics just so some eyeballs might spot something missed?, as the sixpack can be daunting to some not familiar with it's set up Mike
