Re: 1970 440 engine question
[Re: Lawn Monkey]
#2495237
05/12/18 08:24 PM
05/12/18 08:24 PM
Posts: 43,259 Bend,OR USA
Cab_Burge
Will a 1970 440 from an automatic transmission car bolt up to a 4 speed? I;m thinking there might be pilot bearing issues Will the two trans bolt to each other ? No If your asking about putting a NP 833 4 speed into a car with a 440 automatic motor that was never a 4 speed car or had one in it to start with it is doable, but not easy Dang some of them Mopar engineers anyways I did a six cylinder 3 speed car conversion to a 440 with a NP833 O.D. swap last year in a 1966 Dodge Coronet Deluxe two door sedan, I had to add the 4 speed hump which was the major part of that swap as it already had the clutch pedal in it Good luck on yours
[Re: Lawn Monkey]
#2495287
05/12/18 09:48 PM
05/12/18 09:48 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
I've done it, but it's not easy. You need to cut about 1" off the input shaft of the A-833 transmission (cut right at where the bushing wear mark begins) & use a pilot bearing in the back of the engine.
In my case, the crank was partially drilled.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: Lawn Monkey]
#2496473
05/15/18 02:50 PM
05/15/18 02:50 PM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
I used the 53009180 pilot roller bearing shown in the link posted above by CrazyD for the 440 that's in my dad's road runner. It's a '72 block and forged crank w/ an 18 spline 4 speed behind it. Been that way for about 10 years now w/ no issues. Just drive the bearing into the converter hub of the crank.
[Re: Lawn Monkey]
#2496540
05/15/18 05:08 PM
05/15/18 05:08 PM
Posts: 29,654 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
As it is not a precision operation one could use a hand held drill. A pal tried that & broke a wrist. A safer way is to use a small magnetic drill press. (rent one if needed) Mount the flywheel to the crankshaft & use it as the 'table' for the magnetic drill press base.
